Development Build on a port other than 8065?
I followed this guide to setup Mattermost for development on Debian: https://github.com/mattermost/platform/blob/master/doc/developer/Setup.md#ubuntu, but it defaults to building on port 8065 which I already have running a local Mattermost install that my team and I are using at the moment.
What would be easier?
  • Building on a different port
  • Running the locally hosted docker image on a different port?
If I understand correctly the second option would be as simple as:
docker run --name mattermost-dev -d --publish 8066:80 mattermost/platform
I think both are easy. You could also configure via config.json
"ServiceSettings": {
        "ListenAddress": ":8066",
