I want to resolve the issue of \0 character while sending large data in chunks/fragments over web socket in c#. I want to send large data via web socket. I am splitting the large data into chunks based on the buffer size and looping until the end of message send from web socket becomes true.
Client Side:
#region Send
private async Task Send(ClientWebSocket webSocket)
try
if (webSocket.State == WebSocketState.Open)
string stringtoSend = txtOutgoing.Text;
byte[] buffer = encoding.GetBytes(stringtoSend);
bool EOD = false;
// byte[] text = Encoding.UTF8.GetBytes(longString);
int len = 1000;
for (int i = 0; i < buffer.Length;)
byte[] chunk = null;
int j = 0;
if (buffer.Length-i < len)
EOD = true;
chunk = new byte[buffer.Length - i];
else
chunk=new byte[len];
//byte[] chunk = new byte[buffer.Length - i];
while (++j < chunk.Length && i < buffer.Length)
chunk[j] = buffer[i++];
await webSocket.SendAsync(new ArraySegment<byte>(chunk), WebSocketMessageType.Binary, EOD, CancellationToken.None);
//Convert(chunk); //do something with the chunk
// await webSocket.SendAsync(new ArraySegment<byte>(buffer), WebSocketMessageType.Binary, false, CancellationToken.None);
// await Task.Delay(1000);
catch (Exception ex)
#endregion
SERVER
//while (webSocket.State == WebSocketState.Open)
#region
//var receiveBuffer = new byte[bufferSize];
////WebSocketReceiveResult receiveResult = await webSocket.ReceiveAsync(new ArraySegment<byte>(receiveBuffer), CancellationToken.None);
#endregion
var buffer = new ArraySegment<byte>(new byte[1000]);
WebSocketReceiveResult receiveResult = null;
var allBytes = new List<byte>();
do
receiveResult = await webSocket.ReceiveAsync(buffer, CancellationToken.None);
for (int i = 0; i < receiveResult.Count; i++)
allBytes.Add(buffer.Array[i]);
while (!receiveResult.EndOfMessage);
// Optional step to convert to a string (UTF-8 encoding).
var ServerstrReceived = Encoding.UTF8.GetString(allBytes.ToArray(), 0, allBytes.Count);
But in the output I am getting \0 appended in the beginning of each chunk but getting entire data
Output is as below:
\0
<Request
xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance”
xmlns:xsd=“http://www.w3.org/2001/XMLSchema”>
038
P049563445634674574325323674we5476956789057905694565745764256456
<password\0>6919301721649254400252100878956720265267481307739303873300957305
WS001
WSI835180322000000
jES+fXttCsMVnj+jcEE/VjlDp7uzVa85CuezsDMC3Q7HjujL1stguVGIIVg57ZSGHkSvF+0mt+JxkZpy8cZovAx1zaWW7rTYCjaRiwebWsQqf6WKZcgM+w6lYZ8e9aC6\09LGcYOb1/Y45BGyVJF3oSfgMBGj8a3d8FFqyCWcKaZk=
AP+Lf4cJdYTuYwASoN6KEVBZ5Xc5IndY9LHuQD/xEtLHbykGb0EoxlzoLlx3rGpVaBx3AoUBhBL5KqX/qmS/QxtM6zVL4s+xjqtL9idkKRArOvpFAEfKSUTuD2ojmNjGwO7mP+dwcGrAYuGcuFCMXY0lEXLhQ51h0cS0dw0zVulVRKAow/P82BP\0AKAlsSHHFjAB75JgWUwjOEK++F3rsp7mrMOYrWQWo2IQgQ//ph1WK42ywsGxvw+4DxQhC2FSu7yae5nS/upMtOMiCHLUH8mHNjt4RXHV747iPlFWMY0l8u3cz3QEteFEp2e4LzV8vt4bZal8QSqV3btFr2YQ0XQ==
d5v3oN4k8M7yP+YL4v/0j0l86AS3GLRCqaQ3xXriqnJBtdaRqOgnCPfXB0EE3nUvVTSsTw3NaL2de6t0b9twxfURRg\0js+te8b/ObMSlDZn2Fv4dg5H3qnlXdYvB1q7E+9zpvnEcMz23p7E91wp2zRAIpgFxH+l7VHPKfMfyUWx1b+QWBfKPRK2PpXH3Gm1rTSYjbKHv0Ol+Uuz7T7/uBUXDQ2T22/2bLo5pgrIR9+O3sofOi1roDN85gdXmY6zyu1aNGuxLAC7pdhGr1ormwuVFPMQA03FPQ2GmXIIDHaC/jvOUl82YhaRBev/uS8Ckls08yQk5lCVmXUDI4C0jkTvde2ylxOIlzqBPJvmYxv+bEF0B+XHQd/pzndSKR+itr1jKKV\0AL9SoK4XZfVux6HFxsEZlJv0OOUUf7G8Zsro0pXepf5T6ch0LrNhLeEQvyTx18Tzgk+m4gYdWyFsfI1hbutTnF78Y2ORtnsi6U9G1oMdbTcpAPci31DUUvr7Isc7k9AJ77DHoq75UVThUX7k6GXLQoPd1Du6Q1/BpzEcejZBbgtih9TjAr9Bnke3yiIBi7+NTPHInY3Q6kQMkGcH3S5Ez4GtyasFX4BiA1B1Hh8SpNgAMJbMp3yYo7kHNJJ6XTA6PHm6KmO6MmBIrulsL3piV3ZdoRw6FsGugJHAFYXCf4F\09VYY6p+7zGPzwuVi4T2eA0jY7nBxexSRoGSteBvPDYFBz52hNnbcPcR/XisO1F3ctCb7WT5RxsbA8mZprKSuZXB/LsoAjoK/ef9CC2PjSDbjukvLx3BcChjTzfU2O6Y9osV+vI8m3bRkKWjICEeYaZAArJIJ/s1VWHx9kckQCG1MhI2sZkl11xXJksniBIBeVfXXLXqASMPksgSf47zlJfNmIWkQXr/7kvApJfxcmKZLLqknsiSh/RRJB3OvClc+bpAX2OqIsAjDhZPfZNsBjOx3ubCbVUUVDEtUiGeYZ8m\058weufpCT4ebLHNYkxTq67qrs+7Wqgwz4W91te+M8rDtoCfZ3Oob8teC8AyXCcuA0z57MqJ0MEngOHpEnlcvBcCqOlKiij6MZylOOJMU6uu6q7Pu1qoMM+FvdbZPOmtLoFQ1ecTLb0GLldIPs5FEDQtgZRXOloD8FX4YNk86a0ugVDV5xMtvQYuV0g+UirgWzGwa4mnMbic1qseiS5aK6pCOsXqdluPO+xCB8IWpeqEgrhUDNRvTgxA7NedI2IbhSI9NNwZUcZ4M3wEoJXFhIAz8qWHD/Icj7WxHEMDyjRG\0tjpc69g7gBnWQaZw3EQeTFV/UI6UlEepJuLjorv4eVKn/IxrJNrwZRQRJF5WFcpG+BG1mBzXvpmJKYLru0J8kmnLsFFIE5J4T+rh4jRir+RrWtc911nRrsYf5GrWcdUrqyRxg07ImXG4b7vgx1tNykA9yLfUNRS+vsixz01dOGtyO4wS0fJM9U48gxRRR4d90uhZGbaXztCpZwZAaP1BEfUyt5gRsQ8Oy4fmAhjKJ+JT/G+joUko18EKkgiLfPdi2lSBd3HzsvwN76Uv/xIPxqej0NpZN3PRd70nc=
</enc\0ryptedRequestData>
