I’m not able to do it due to an error with existing users. It seems there are conflicts with already registered emails.
What I’ve tried and what I’ve got
Importing the file with the mmctl command. This gives the following error:
$ sudo docker exec -it -w /mattermost/config mattermost-mattermost-1 mmctl --local import upload ./import1/mattermost-bulk-import.zip
Upload session successfully created, ID: 8z59bc1gbbg7zkbii6hhgy5gfc
$ sudo docker exec -it -w /mattermost/config mattermost-mattermost-1 mmctl --local import list available
8z59bc1gbbg7zkbii6hhgy5gfc_mattermost-bulk-import.zip
$ sudo docker exec -it -w /mattermost/config mattermost-mattermost-1 mmctl --local import process 8z59bc1gbbg7zkbii6hhgy5gfc_mattermost-bulk-import.zip
Import process job successfully created, ID: d6ue8e3iu7nnzfec9kiggjbk6e
$sudo docker exec -it -w /mattermost/config mattermost-mattermost-1 mmctl --local import job show d6ue8e3iu7nnzfec9kiggjbk6e
Status: error
Created: 2023-07-03 18:55:46 +0000 UTC
Started: 2023-07-03 18:55:52 +0000 UTC
Data: map[error:Error during job execution. — importUser: An account with that email already exists., invalid input: entity: User field: email value: xxxxxxxxx@gmail.com import_file:8z59bc1gbbg7zkbii6hhgy5gfc_mattermost-bulk-import.zip line_number:105]
(the email is just a regular one, I just replaced it here with ‘xxxxxxxxx’ for privacy)
I manually unzip and remove the emails in file mattermost_import.jsonl, letting all the fields blank. I zip it back and repeat the same steps and what I get is:
$ sudo docker exec -it -w /mattermost/config mattermost-mattermost-1 mmctl --local import job show pkc5rs6w6ir4zg5ozdc4tzayxw
Status: error
Created: 2023-07-04 08:53:04 +0000 UTC
Started: 2023-07-04 08:53:17 +0000 UTC
Data: map[error:Error during job execution. — BulkImport: User email has an invalid length. import_file:xce1ny8u57b1tecekiwmqze7dy_mattermost-bulk-import.zip line_number:102
I completely remove all the email fields and repeat it again.
sudo docker exec -it -w /mattermost/config mattermost-mattermost-1 mmctl --local import job show 9wt8wfezxpfmpby6375ts13epy
Status: error
Created: 2023-07-04 09:47:07 +0000 UTC
Started: 2023-07-04 09:47:18 +0000 UTC
Data: map[error:Error during job execution. — BulkImport: Missing required user property: email. import_file:uxbepiskgjy5tnbnks719g9wto_mattermost-bulk-import.zip line_number:102]
The e-mail attribute is mandatory for Mattermost users, so removing them from the import file will lead to the errors you’re seeing in step 2 and 3. Are you trying to merge platforms here? So is there already a local user base and posts in the Mattermost server and you try to import slack data additionally to it? I’m not sure if this is supported. What would you expect to happen when there’s a local user X and one in the slack export? Should these users messages be merged? What about channels with the same names? Should they also be merged or should new ones be created then?
Some users already registered themselves in Mattermost with the same email they had in Slack. In any case, what I’m trying is to import all their posts into a “empty” new team I just created. So, answering to your questions, I don’t expect channels to be merged, since there are none in the new Mattermost team I created to import everything into.
I hoped the import process to automatically match them both, but maybe this is not what it is meant to do.
Just for you to know, I previously tried to do all the above process without having created a team with the name of the export, and what I got was the following error (so only then I created the team and got the errors I explained in my first post):
$ sudo docker exec -it -w /mattermost/config mattermost-mattermost-1 mmctl --local import job show 9oj1auertjgn8kuciazgzo936e
Status: error
Created: 2023-07-06 08:13:57 +0000 UTC
Started: 2023-07-06 08:14:06 +0000 UTC
Data: map[error:Error during job execution. — BulkImport: Error importing channel. Team with name "vizteam" could not be found., resource: Team id: name=vizteam import_file:17sj1rxnqbgifcho679jmk6bdr_mattermost-bulk-import.zip line_number:2]
All in all, I suspect I’m really missing something. How should I do it instead? Should I kick out all the registered users, then perform the import and invite them again to Mattermost?
We’re also facing the same scenario [edit: we’re using Kubernetes instead of Docker, but that is unlikely to make a difference], and have taken the same steps and gotten the same results as @HerManNav. We have an older Slack corporate export that predates our use of Mattermost, and we wanted to import that data. We specifically avoided creating identically named teams in Mattermost (in accordance with the documentation), and created a new team workspace with the same name as our old Slack workspace.
We recommend you create a new team in Mattermost to hold the imported Slack data. You can import this into an existing team, but ensure there are no channel name collisions. Also, make sure that all users in Mattermost have the same username as in Slack, otherwise the import will fail.
It’s not clear from the documentation at all that importing Slack data to an in-use Mattermost instance is not supported when you’re specifically importing into a “blank”/“empty” team. This does seem like a bug.
I talked to the users and they told me that they were still using Slack and that they hadn’t started an actual transition to Mattermost yet. So, as they only had a few chats in MM, I tried one last thing:
I deleted all their accounts in MM (and therefore all their messages were lost)
I created a new “empty” team, with the name of the Slack export, just as I explained in my previous post here
And I repeated the steps in my first post
This didn’t work either. So I stopped trying and just assumed that the mmctl import utility is not mature enough.
