# Mattermost send email notification problems
**URL:** <https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529>\
**Category:** Troubleshooting\
**Created:** [October 8, 2020, 3:25pm UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529 "2020-10-08T15:25:19Z")\
**Posts on this page:** 19\
**Page:** 5
<div class="post-metadata">
**Author:** ![Ada](https://avatars.discourse-cdn.com/v4/letter/a/6a8cbe/32.png) [@Ada](https://forum.mattermost.com/u/Ada)\
**Post date:** [January 20, 2021, 3:03am UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/81 "2021-01-20T03:03:08Z")
</div>
Dear @XxLilBoPeepsxX ,
I would like to reply you that there is an error, when I typed `sudo systemctl start apache2`. Please refer to below image.
 ![Screenshot from 2021-01-20 10-41-31](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/e/eefb4c867ade58757b5b6ded65eaf41135d1bd47.png)
When I typed `systemctl status apache2.service`, it displays below image.
 ![Screenshot from 2021-01-20 10-44-28](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/7/7945d27897255beb60cb1d9babe5f020e4cbc968.png)
While I typed `journalctl -xe`, it show below images.
 ![Screenshot from 2021-01-20 10-49-41](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/a/a815f8fa66a2c4ba757205976962e7e9dc5e0ee6.png)
Below is the content of 100-http-mat.invisiblenotes.conf and there is no error in apache log. Thank you.
 ![Screenshot from 2021-01-20 11-06-42](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/8/8c49956c60061ff71d544f84535a78eda7468df7.png)
**Author:** ![XxLilBoPeepsxX](https://sea2.discourse-cdn.com/flex020/user_avatar/forum.mattermost.com/xxlilbopeepsxx/32/4993_2.png) [@XxLilBoPeepsxX](https://forum.mattermost.com/u/XxLilBoPeepsxX)\
**Post date:** [January 21, 2021, 4:39pm UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/82 "2021-01-21T16:39:36Z")
</div>
Could you run the command `sudo a2enmod *proxy*` and then attempt to restart the Apache server with `sudo systemctl restart apache2` and let me know if it works?
**Post date:** [January 22, 2021, 2:41am UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/83 "2021-01-22T02:41:12Z")
</div>
I would like to reply you that it still have errors. Please refer to below images.
 ![Screenshot from 2021-01-22 10-20-31](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/8/83486a37b29bb5b87a9b210ac3211e7cb19b8f5b.png)
 ![Screenshot from 2021-01-22 10-20-58](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/9/912d40b07a0553c96f134266859505d79a1dcd8f.png)
When I typed `systemctl status apache2.service` , it displays below image.
 ![Screenshot from 2021-01-22 10-39-17](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/d/d8d266a1416c19ba4f71a34507e4b61b042c53ae.png)
While I typed `journalctl -xe` , it show below images.
 ![Screenshot from 2021-01-22 10-38-22](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/3/38d38008b338093d90dbe3bde3f323ff1edaee32.png)
**Post date:** [January 25, 2021, 2:07am UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/84 "2021-01-25T02:07:19Z")
</div>
Dear @XxLilBoPeepsxX,
I would like to ask that do you receive my reply? Thank you.
**Post date:** [January 25, 2021, 12:44pm UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/85 "2021-01-25T12:44:55Z")
</div>
Hello! I’m sorry for the delay in responding, could you run the command `sudo apache2ctl -M` and provide the output here please? I just want to check to make sure the right modules are enabled, since that is 99% likely to be causing the issue. Thanks!
**Post date:** [January 26, 2021, 3:03am UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/86 "2021-01-26T03:03:32Z")
</div>
Below is the output of running the command `sudo apache2ctl -M`. Thank you.
 ![Screenshot from 2021-01-26 10-57-18](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/e/eb8ecd69a14b05dbf78523552d936a893b6cb140.png)
Below is the content of mat.invisiblenotes.com.conf.
 ![Screenshot from 2021-01-26 10-56-58](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/4/488650ed604e75634865e8f4a8bd36f73544a5ac.png)
**Post date:** [January 28, 2021, 2:11pm UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/87 "2021-01-28T14:11:56Z")
</div>
Hey I’m sorry for the delay in my response, what about if you run the command
`sudo apache2ctl -t -D DUMP_MODULES`, what do you get for your output then?
**Post date:** [January 29, 2021, 2:57am UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/88 "2021-01-29T02:57:41Z")
</div>
Below is the output of run the command `sudo apache2ctl -t -D DUMP_MODULES`. Thank you.
 ![Screenshot from 2021-01-29 10-55-12](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/5/5030226d0fe0fca82beee4c6e5341ea85e79c9db.png)
**Post date:** [February 1, 2021, 3:54pm UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/89 "2021-02-01T15:54:19Z")
</div>
Could you share the output of the command `sudo cat /etc/apache2/apache.conf` with me by any chance? According to my research, this seems to have something to do with the way that the .htaccess file system is setup and interpreted, and this file should have the configuration information in it.
**Post date:** [February 2, 2021, 4:15am UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/90 "2021-02-02T04:15:24Z")
</div>
Below is the output of the command `sudo cat /etc/apache2/apache.conf`. Thank you.
 ![Screenshot from 2021-02-02 12-11-58](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/3/3060d6a0788146143a85a5c703b973598aa2a7b9.png)
**Post date:** [February 7, 2021, 7:02pm UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/92 "2021-02-07T19:02:42Z")
</div>
Well I think that is the issue, if your missing the entire main Apache web server configuration file, then there is nothing to tell Apache what it is and isn’t allowed to do globally. Could you run the command `sudo ls -alh /etc/apache2/` and provide the output? I just want to check to see what all is present in your servers directory so we can get everything that is missing where it needs to go. Thanks!
**Post date:** [February 8, 2021, 2:35am UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/93 "2021-02-08T02:35:08Z")
</div>
I would like to reply you that below is the image of running the command `sudo ls -alh /etc/apache2`. Thank you.
 ![Screenshot from 2021-02-08 10-30-20](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/5/50edb36eeb0188ecfb7089adab8c464362e9824d.png)
**Post date:** [February 8, 2021, 11:41pm UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/94 "2021-02-08T23:41:18Z")
</div>
🤦‍♂️ I just realized I made a mistake in the command, that explains the issue. It’s so different typing it out in instructions instead of doing it myself, its such a second nature thing to me now that I don’t normally actually think about the commands I’m using. I’m so sorry for the confusion. Could you provide the output of the correct command, which is `sudo cat /etc/apache2/apache2.conf` please?
**Post date:** [February 9, 2021, 2:34am UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/95 "2021-02-09T02:34:20Z")
</div>
I would like to reply you that below is the images of running the command `sudo cat /etc/apache2/apache2.conf`.
 ![Screenshot from 2021-02-09 10-21-55](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/a/a5795e7f6e5b561e0159fa89d8b3e88a1bb4a517.png)
 ![Screenshot from 2021-02-09 10-23-44](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/9/943e82ef58bc4b113a1612451d1b88748db578d0.png)
 ![Screenshot from 2021-02-09 10-24-54](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/4/4a324e8e776b722f5cbc1889581b3a6aab7a7e58.png)
 ![Screenshot from 2021-02-09 10-26-38](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/e/eab8031f6047b0d15448263dd4c7b2af09648eba.png)
 ![Screenshot from 2021-02-09 10-28-06](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/8/8394c84230629cf23504b129c91ff78f500f43c2.png)
**Post date:** [February 9, 2021, 8:53pm UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/96 "2021-02-09T20:53:52Z")
</div>
Thank you so much! I believe I see the issue, which is that the Apache VirtualHost configuration file is attempting to use mod\_proxy rules while there is no document root set, which basically means that the server doesn’t know if it is supposed to allow or deny the rules from being applied to the website, because it doesn’t know where in the server it is. Basically, you should be able to (hopefully) fix this by adding the following line to your VirtualHost configuration file we created above.
`DocumentRoot /var/www/html`
You can see where to put this in the file from [here](https://www.diffchecker.com/BI1kxtHA) where it is clearly highlighted in green, or from the screenshot attached which is also the same thing.
 ![image](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/e/ea0fa76f24b5f20babd537c7d45116ae28daf518.png)
**Post date:** [February 10, 2021, 3:02am UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/97 "2021-02-10T03:02:17Z")
</div>
I would like to reply you that when I add `DocumentRoot /var/www/html`, it still have problem of running sudo apachectl enmod mod\_rewrite mod\_proxy mod\_proxy\_http mod\_proxy\_wstunnel. Please refer to below images. Thank you.
 ![Screenshot from 2021-02-10 10-59-25](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/2/254304f38633fdd9342a424136219baef7c0ac93.png) ![Screenshot from 2021-02-10 11-00-42](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/d/d41cdb5e320d81d00f431da4998f053ed8789a08.png)
**Post date:** [February 11, 2021, 8:29pm UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/98 "2021-02-11T20:29:14Z")
</div>
The command is `sudo a2enmod rewrite proxy proxy_http proxy_wstunnel`
The reason it didn’t work is because the wrong command was used.
**Post date:** [February 16, 2021, 2:29am UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/99 "2021-02-16T02:29:55Z")
</div>
I would like to reply you that when I run `sudo a2enmod rewrite proxy proxy_http proxy_wstunnel` and `sudo systemctl reload apache2`, it still have errors.
 ![Screenshot from 2021-02-16 10-22-15](https://us1.discourse-cdn.com/flex020/uploads/mattermost/original/2X/c/c6adb29f7f32ab794ef7be14e9d9205366f23fdd.png)
**Post date:** [February 18, 2021, 10:28pm UTC](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529/100 "2021-02-18T22:28:00Z")
</div>
That error means that you never started the Apache service, you can start the Apache web server with the command `sudo systemctl enable apache2 && sudo systemctl start apache2`
[Previous page](https://forum.mattermost.com/t/mattermost-send-email-notification-problems/10529.md?page=4)
