Hey folks, I’m pretty new to Linux, and have been trying to get the MMETL tool working for the past few hours to no avail. Go appears to have downloaded it into the right folder, as it created bin and src folders put the things inside of it, but when I try and run any of the commands in terminal it just says “mmetl: command not found”. I feel like I must be missing something very obvious with Linux as no one has posted an issue about it anywhere as far as I can see. I’m running Ubuntu 20.04 LTS 64-Bit. Any help would be greatly appreciated!
It appears to have been a bad go install, as it is now downloading a lot more things.
Hi, @Franktarkenton
Can I confirm that the mmetl command is working properly on your end now and what was the ultimate solution you implemented to get the initial issue resolved?
