When users receive a PM, the taskbar icon shows a red indicator. Same indicator for when a user is mentioned, either directly, or via a group mention like @here, @all, etc.
However, when they receive a PM in a multi-user PM, they only see a blue indicator.
We’ve had few reports on this before but we’ve been unable to reproduce this on our end. Would you be able to help share any other details about reproduction steps and/or your environment?
Certainly! Reproduction steps are straightforward:
Be in a multi-user PM.
Go to another channel.
Receive a message in the PM.
Environment:
We’re running https://github.com/mattermost/mattermost-docker/, latest version (5.23.1). We use the Postgres DB, default app. We do not use the web container, but run our own nginx proxy. Configs are below.
docker-compose.yml
version: "3"
services:
db:
build: db
read_only: true
restart: unless-stopped
volumes:
- ./volumes/db/var/lib/postgresql/data:/var/lib/postgresql/data
environment:
- POSTGRES_USER=mmuser
- POSTGRES_PASSWORD={REDACTED}
- POSTGRES_DB=mattermost
app:
build: app
ports:
- "8000:8000"
volumes:
- ./volumes/app/mattermost/logs:/mattermost/logs:rw
- ./volumes/app/mattermost/plugins:/mattermost/plugins:rw
- ./volumes/app/mattermost/client-plugins:/mattermost/client/plugins:rw
# to avoid Token request failed: certificate signed by unknown authority (link: https://github.com/mattermost/mattermost-server/issues/13059)
# - <path_to_your_gitlab_pki>/pki_chain.pem:/etc/ssl/certs/pki_chain.pem:ro
environment:
# set same as db credentials and dbname
- MM_USERNAME=mmuser
- MM_PASSWORD={REDACTED}
- MM_DBNAME=mattermost
- MM_SQLSETTINGS_DATASOURCE=postgres://mmuser:{REDACTED}@db:5432/mattermost?sslmode=disable&connect_timeout=10
# The web container is unused. See /etc/nginx/sites-available/mattermost for web proxy config
# web:
# build: web
# ports:
# - "80:80"
# - "443:443"
# read_only: true
# restart: unless-stopped
# volumes:
# # This directory must have cert files if you want to enable SSL
# - ./volumes/web/cert:/cert:ro
# - /etc/localtime:/etc/localtime:ro
# # Uncomment for SSL
# # environment:
# # - MATTERMOST_ENABLE_SSL=true
I am not on a Mac, no. I’m on Windows, using the desktop (Electron) client. Screenshots in the OP are from my system.
Chatting with two of my colleagues who’ve also seen the issue, one is on Windows and the other is on MacOS. Both use Mattermost in the browser. Both use Chrome as their standard browser. My colleague using MacOS has also reproduced it in Firefox when using that.
Need anything further here Amy? Any luck with reproduction? To rule out any local environment issues, I tested this on demo.mattermost.com, and encountered the same issue - blue notification icon instead of red.
I asked our desktop app team and they didn’t have ideas on this. I’ll next escalate this to our general R&D team and see if anyone else could help take a look.
@amy.blais, could this be because group messages don’t count as mentions in the same way as a direct messages do? I seem to recall a planned change in this regards to make group messages behave like direct messages as such.
