Path Based Ingress not working, Please check connection, Mattermost unreachable. If issue persists, ask administrator to check WebSocket port
:“Failed to upgrade websocket connection.”,“caller”:“web/context.go:111”,“path”:“/mm/api/v4/websocket”,“request_id”:"or4g5dey5fdidkfbg474fj1 │
I have deployed in Kubernetes and exposed with path base ingress under /mm, but i am facing this web socket issue, please help me to fix this issue,
I have attached my ingress resource file for reference.
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
namespace: mattermost
annotations:
nginx.ingress.kubernetes.io/rewrite-target: /mm/$2
nginx.ingress.kubernetes.io/proxy-read-timeout: “3600”
nginx.ingress.kubernetes.io/use-regex: “true”
nginx.ingress.kubernetes.io/ssl-redirect: “true”
nginx.ingress.kubernetes.io/enable-cors: “true”
nginx.ingress.kubernetes.io/cors-allow-origin: “*”
nginx.ingress.kubernetes.io/configuration-snippet: |
proxy_set_header Connection “upgrade”;
spec:
ingressClassName: nginx
rules:
  • host: devops.assam.statedatacenter.in
    http:
    paths:
    • path: /mm(/|$)(.*)
      pathType: ImplementationSpecific
      backend:
      service:
      port:
      number: 8065
See if Integrations configuration settings - Mattermost documentation helps.
