Hi, are there any restrictions in running mm 4.1.0 on PostgreSQL10?
would like to upgrade PostgreSQL.
@hi @wambacher as of now we haven’t tested MM running on PostgreSQL 10, would you be interested in set up a local copy, tested and report back?
It will be highly appreciate it.
@elias: sorry, missed your answer.
yes, i may test this on a local copy, but don’t have the time right now. (mm licence upgrade is making trouble)
the first step to update i think have to update jdbc driver
but i can’t find how to update it. can you figure out?
i think - but i’m not 100% shure - that jdbc is part of the usual postgresql packages. i dont’t remember havin installed jdbc on my mattermost server, it just runs.
walter
i just comeback to confirm i can run with postgresql 10 without do anything.
before i mistake on password and careless when check log.
