Trying to enable MFA causes invalid token error.
getting following error in debug level log.
Activate code=500 rid=i1u5w7spyfdn9xe13tfa334cee uid=zn8wsf6pztgsikxfnrwhkz1okc ip=157.191.44.90 Invalid MFA token [details: ]
Repo steps:
Press the “Add MFA to your account” button
Scan the barcode
Enter the token
Receive the error “Invalid MFA token”
lfbrock
#2
Hi @archanbhatt,
This is typically caused by the server clock being out of sync. If it’s not your server clock causing the issue, can you:
- Check the device clock to make sure it’s using network time and is not manually set
- Let us know what authentication method (eg email, LDAP) the account is using?
- Let us know if your email has any strange characters in it? It’s unlikely, but something like this could be causing issues with the token generation.
