Upgrading Mattermost Server with a Script
Important: This unofficial guide is maintained by the Mattermost community and this deployment configuration is not yet officially supported by Mattermost, Inc. Community testing, feedback, and improvements are welcome and greatly appreciated.
Preparing the script
Copy and save the following script to your Mattermost server as upgrade_mattermost.sh.
   #!/usr/bin/env bash
   # Immediately exit if a command run from a loop, a pipeline or a compound
   # command statement fails or a variable is used unset.
   set -e
Configuration - please adapt it to your environment
   # Mattermost path
   mattermostdir="/opt/mattermost"
   # Backup path
   backupdir="/opt"
   # Temporary path for download
   downloaddir="/tmp"
   # Specify the edition you use
   #edition="Team"
   edition="Enterprise"
   # Start with plugins? Set 1 for starting with plugins active
   plugins=0
   # Set 1 for overriding the database backup question
   backupdatabase=0
  # Check dependencies
   if ((EUID != 0)); then
   	echo "[-] This script needs to be run as root to work properly. Aborted."
   	exit 1
   fi
   if ! type "systemctl" >/dev/null 2>&1 && ! type "service" >/dev/null 2>&1; then
   	echo "[-] The daemon manager (systemd or sysvinit) is not accessible. Aborted."
   	exit 1
   fi
   if ! type "wget" >/dev/null 2>&1 && ! type "curl" >/dev/null 2>&1; then
   	echo "[-] A download tool like wget or curl is not accessible. Aborted."
   	exit 1
   fi
   # Check requirements
   if [[ "${edition}" != "Team" ]] && [[ "${edition}" != "Enterprise" ]]; then
   	echo "[-] The edition must either be \"Team\" or \"Enterprise\". Aborted."
   	exit 1
   fi
   # Check config variables
   test -d ${backup}
   test -d ${downloaddir}
   test -d ${mattermostdir}
   # Ask for database backup
   if [ "${backupdatabase}" -eq 0 ]; then
   	read -r -p "[?] Do you have a current backup of the Mattermost database? [Y/n] " input
   	case "$input" in
   		[yY])
   			echo "[+] Starting the update process of Mattermost..."
   			echo "[-] Please create a backup and start again"
   			exit 1
   	esac
   fi
   # Check if Mattermost exists in the path provided above
   if [ ! -f "${mattermostdir}/bin/mattermost" ];  then
   	echo "Mattermost not found please check the path for the Mattermost directory"
   	exit 1
   fi
   # Get version from argument
   if [ -z "${1}" ]; then
   	echo "Please specify the version of Mattermost to download"
   	exit 1
   fi
   version="${1}"
   if [[ "${edition}" == "Team" ]]; then
   	url="https://releases.mattermost.com/${version}/mattermost-team-${version}-linux-amd64.tar.gz"
   else
   	url="https://releases.mattermost.com/${version}/mattermost-${version}-linux-amd64.tar.gz"
   fi
   # Main
   # Get the file
   function get_the_file() {
   	echo "[+] Downloading Mattermost ${edition} \"${version}\"..."
   	if type "curl" >/dev/null 2>&1; then
   		if ! curl -LC - "${url}" -o "${downloaddir}/mattermost-upgrade.tar.gz"; then
   			echo "[-] An issue occurred when downloading the Mattermost update package."
   			exit 1
   		fi
   	else
   		if ! wget "${url}" -o "${downloaddir}/mattermost-upgrade.tar.gz"; then
   			exit 1
   		fi
   	fi
   	echo "[+] The Mattermost update package has been downloaded with successful"
   # Check previous download
   if [ -e "${downloaddir}/mattermost-upgrade.tar.gz" ]; then
   	read -r -p "[?] A previous download exists. Do you want to replace it by a new one? [Y/n " input
   	case "$input" in
   		[yY])
   			echo "[+] Remove previous download."
   			rm -rf "${downloaddir}/mattermost-upgrade.tar.gz"
   			get_the_file
   	esac
   else
   	get_the_file
   fi
   echo "[+] Extracting Mattermost update package..."
   mkdir -p "${downloaddir}/mattermost-upgrade"
   tar -xf "${downloaddir}/mattermost-upgrade.tar.gz" -C "${downloaddir}/mattermost-upgrade/"
   echo "[+] Stopping Mattermost service..."
   if type systemctl >/dev/null 2>&1;  then
   	systemctl stop mattermost
   else
   	service mattermost stop
   fi
   if pgrep mattermost > /dev/null; then
   	echo "[-] Mattermost is still running. Update not possible. Aborting..."
   	rm -rf "${downloaddir}/mattermost-upgrade"
   	rm -f "${downloaddir}/mattermost-upgrade.tar.gz"
   	exit 1
   fi
   echo "[+] Creating backup of Mattermost..."
   cp -ra "${mattermostdir}" "${backupdir}/mattermost-backup-$(date +'%F-%H-%M')/"
   echo "[+] Preparing update..."
   USER="$(stat -c '%U' ${mattermostdir}/bin/mattermost)"
   GROUP="$(stat -c '%G' ${mattermostdir}/bin/mattermost)"
   chown -hR "$USER":"$GROUP" "${downloaddir}/mattermost-upgrade/"
   # Clean up Mattermost directory
   find "${mattermostdir}" -mindepth 1 -maxdepth 1 -not \( -path "${mattermostdir}/config" -o -path "${mattermostdir}/logs" -o -path "${mattermostdir}/plugins" -o -path "${mattermostdir}/data" -o -path "${mattermostdir}/client" \) -exec rm -rf {} \;
   find "${mattermostdir}/client" -mindepth 1 -maxdepth 1 -not \( -path "${mattermostdir}/client/plugins" \) -exec rm -rf {} \;
   # Rename plugin directory
   if [ "${plugins}" -eq 0 ];  then
   	echo "[+] Renaming plugin folders..."
   	if [ -d "${mattermostdir}/plugins/" ]; then
   		mv "${mattermostdir}/plugins/" "${mattermostdir}/plugins~"
   	fi
   	if [ -d "${mattermostdir}/client/plugins/" ]; then
   		mv "${mattermostdir}/client/plugins/" "${mattermostdir}/client/plugins~"
   	fi
   fi
   echo "[+] Updating Mattermost..."
   cp -an "${downloaddir}/mattermost-upgrade/mattermost/"* "${mattermostdir}"å
   echo "[+] Cleaning Mattermost temporary files..."
   rm -rf "${downloaddir}/mattermost-upgrade/"
   rm -f "${downloaddir}/mattermost-upgrade.gz"
   echo "[+] Allowing Mattermost to run on port 0-1023..."
   setcap cap_net_bind_service=+ep "${mattermostdir}/bin/mattermost"
   echo "[+] Starting Mattermost service..."
   	systemctl start mattermost
   else
   	service mattermost start
   fi
   echo "[+] Mattermost updated with successful"
   	echo "*************************************************"
   	echo "Dont forget to reactivate your plugins"
   	echo "mv \"${mattermostdir}/plugins~\" \"${mattermostdir}/plugins\""
   	echo "mv \"${mattermostdir}/client/plugins\" \"${mattermostdir}/client/plugins~\""
   fi
Make it executable.
   # chmod +x ./upgrade_mattermost.sh
Please adjust the parameters at the beginning of the script according to your environment.
Start the script
To start the update process, start the script and add the desired version number as an argument.
   # ./upgrade_mattermost.sh <VERSION>
Example:
   # ./upgrade_mattermost.sh 5.26.0
Hi @justinegeffen!
Please take a look at some improvements to the script.
I added a check for free space before doing the upgrade.
Rewrote the “Check config variables” section.
Removed character “å” from the end of the “Updating Mattermost…” section.
#!/usr/bin/env bash
set -e
##  Configuration - please adapt it to your environment  ##
# Mattermost path
# Backup path
backupdir="/opt"
downloaddir="/tmp"
#edition="Team"
plugins=0
backupdatabase=0
    exit 1
fi
    exit 1
fi
    exit 1
fi
    exit 1
fi
# Check free space
echo "[+] Calculating disk usage by Mattermost..."
USAGE=$(du -sk "${mattermostdir}" | awk -F ' ' '{print $1}')
FREE=$(df -k --output=avail "${backupdir}" | tail -n1)
if [[ $FREE -lt $USAGE\*2 ]]; then
    echo "[-] Free space on backup path not enough. Aborted."
    exit 1
fi
# Check paths from config variables
if [[ ! -d ${backupdir} ]]; then
    echo "[-] ${backupdir} not found please check the path for the backup directory."
    exit 1
fi
if [[ ! -d ${downloaddir} ]]; then
    echo "[-] ${downloaddir} not found please check the path for the download directory."
    exit 1
fi
if [[ ! -d ${mattermostdir} ]]; then
    echo "[-] ${mattermostdir} not found please check the path for the Mattermost directory."
    exit 1
fi
    case "$input" in
        [yY])
            exit 1
    esac
fi
    exit 1
fi
    exit 1
fi
version="${1}"
else
fi
# Main
# Get the file
            exit 1
        fi
    else
            exit 1
        fi
    fi
    read -r -p "[?] A previous download exists. Do you want to replace it by a new one? [Y/n] " input
    case "$input" in
        [yY])
            get_the_file
    esac
else
    get_the_file
fi
else
fi
    exit 1
fi
    fi
    fi
fi
else
fi
fi
