This is very strange, because for the experiment, the windows firewall and antivirus were disabled at that time. And this is not a single computer problem. The same thing happens on three different devices.
I also have the exact same problem, only 1 way voice is working and its always on the caller no matter on what device, the caller voice will always working fine, but callee can not.
Caller ➜ Callee = Audio OK
Callee ➜ Caller = No Audio
I even test with a coturn server to make sure the peer to peer connection on NAT/ISP strict works.
and from the logs i can see this :
Incoming unhandled RTP ssrc(…), OnTrack will not be fired. mid RTP Extensions required for Simulcast
Could not determine PayloadType for SSRC …
from chatgpt show me that the problem is "
- the calls plugin does not receive RTP MID extension,
OnTrack()WebRTC is not called- RTP stream is not decoded, so the callee can not hear anything.
please help.
Thanks
After spending all night I finally found the root cause of this.
On the log i see this error :
on my case, this happen when I activate this menu “Enable simulcast for screen sharing (Experimental)” from System Console → Calls
now voice is working both ways.
hope it can help the others.
Thanks
