(Apologies if this is a configuration setting, a duplicate, or expected - have only started seeing this since the update)
It appears that webhooks respond with a 401 if the webhook owner does not have an active session.
Checking for token expiry / generating a new token before a webhook seems to work so far as a fix (even though webhooks don’t use tokens. It also seems that using the login API does not give a token expiry time, and hasn’t for a while)
Mattermost: 5.27.0
Create a new account
Create a new incoming webhook on the account
Use the API to obtain a mattermost token, use the webhook (this should work)
Wait until the token session expires, use the webhook
Webhook should still work
Webhook fails with HTTP 401:
{“id”:“api.context.session_expired.app_error”,“message”:“Invalid or expired session, please login again.”,“detailed_error”:"",“request_id”:"…",“status_code”:401}
