Addon Calls wont start port 8443 in use
I’m trying to upgrade to version 10.4.2 and I’m getting this error from the Calls addon.
Calls (com.mattermost.calls - 0.27.0)
Integrates real-time voice communication in Mattermost
This plugin failed to start. failed to create TCP listener: listen tcp4 :8443: bind: address already in use
Checking the server something is trying to use the port but multiple times.
Checking the server I get:
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:8443 0.0.0.0:* LISTEN -
tcp6 0 0 :::22 :::* LISTEN -
tcp6 0 0 :::80 :::* LISTEN -
tcp6 0 0 :::443 :::* LISTEN -
udp 0 0 127.0.0.1:323 0.0.0.0:* -
udp 0 0 x.x.x.x:68 0.0.0.0:* -
udp 0 0 x.x.x.x:8443 0.0.0.0:* -
udp 0 0 127.0.0.1:8443 0.0.0.0:* -
udp6 0 0 ::1:323 :::* -
udp6 0 0 fe80::e8:3aff:feb6::546 :::* -
[ec2-user@ip-172-31-6-103 ~]$
You should be able to pass an argument to netstat or ss to get the process that’s listening on 8443 lsof could help, too.
Is this your server, so do you have root privileges? Then you may use this command:
sudo netstat -tulpen | grep 8443
(or without “sudo” when you are root right now)
On the right side, you will see the process id and name of the process using this port.
I had this problem too a while ago. Calls itself had blocked this port and only a restart of the virtual machine helped finally.
I tried restarting but the problem persists.
The process name is the same for all the entries in the previous list
2258/plugins/com.ma
It seems the plugin is trying multiple connections and blocking himself up.
Any ideas what could be causing it.
Cheers
I’m still getting the same error
MM Server 10.5.1
“caller”: “app/plugin_api.go:1011”,
“level”: “error”,
“msg”: “failed to create TCP listener: listen tcp4 :8443: bind: address already in use”,
“origin”: “main.(*Plugin).OnActivate activate.go:192”,
“plugin_id”: “com.mattermost.calls”,
“timestamp”: “2025-02-24 03:14:32.431 Z”
Same issue here after upgrading from Mattermost 9.3.0 to 10.4.2 and Calls from 0.27 to 1.5.1. Has someone found a solution ?
