Can not activate plugins
bonjour, dans mattermost il m’est impossible d’activer les plugins : Jitsi, todo… (en fait aucun n’est activable)
hello II can not activate all the plugins
Jitsi (jitsi - 2.0.0)
Jitsi audio and video conferencing plugin for Mattermost.
Désactiver - Retirer - Paramètres
Ce plugin n’a pas pu démarrer. Veuillez vérifier vos journaux à la recherche d’erreurs.
Todo (com.mattermost.plugin-todo - 0.4.0)
This plugin makes it easy to keep track of Todo issues and get daily reminders.
je suis sur une installation neuve de mattermost et je n’ai pas fais de configuration particulière.
j’ai installer mattermost sous mondomaine.tld/mattermost
ce n’est pas mon domaine principal sur mon yunohost.
merci
-- Logs begin at Thu 2021-03-18 21:59:27 UTC, end at Fri 2021-03-19 09:39:33 UTC. --
Mar 19 08:33:15 mattermost[962]: {"level":"error","ts":1616142795.3456683,"caller":"mlog/log.go:232","msg":"Unable to activate plugin","plugin_id":"com.mattermost.plugin-todo","error":"unable to start plugin: com.mattermost.plugin-todo: fork/exec plugins/com.mattermost.plugin-todo: permission denied","errorVerbose":"fork/exec plugins/com.mattermost.plugin-todo: permission denied\nunable to start plugin: com.mattermost.plugin-todo\ngithub.com/mattermost/mattermost-server/v5/plugin.(*Environment).Activate\n\tgithub.com/mattermost/mattermost-server/v5/plugin/environment.go:268\ngithub.com/mattermost/mattermost-server/v5/app.(*App).SyncPluginsActiveState.func2\n\tgithub.com/mattermost/mattermost-server/v5/app/plugin.go:132\nruntime.goexit\n\truntime/asm_arm64.s:1148"}
Mar 19 08:43:26 mattermost[962]: {"level":"info","ts":1616143406.4263694,"caller":"expirynotify/worker.go:85","msg":"Worker: Job is complete","worker":"ExpiryNotify","job_id":"k6g4bugidj8898ejsm4g76sjyc"}
Mar 19 08:53:26 mattermost[962]: {"level":"info","ts":1616144006.521327,"caller":"expirynotify/worker.go:85","msg":"Worker: Job is complete","worker":"ExpiryNotify","job_id":"jgb3rehudb899qaom7h9kq7qrr"}
Mar 19 09:03:26 mattermost[962]: {"level":"info","ts":1616144606.627167,"caller":"expirynotify/worker.go:85","msg":"Worker: Job is complete","worker":"ExpiryNotify","job_id":"4rqb3kh97pnitnjcfcysmrcato"}
Mar 19 09:13:26 mattermost[962]: {"level":"info","ts":1616145206.7178981,"caller":"expirynotify/worker.go:85","msg":"Worker: Job is complete","worker":"ExpiryNotify","job_id":"7ex4bggp6j85bx6pdo3f4orzza"}
Mar 19 09:20:04 mattermost[962]: {"level":"info","ts":1616145604.2046227,"caller":"app/server.go:767","msg":"Stopping Server..."}
Mar 19 09:20:04 mattermost[962]: {"level":"info","ts":1616145604.2048132,"caller":"app/web_hub.go:115","msg":"stopping websocket hub connections"}
Mar 19 09:20:04 mattermost[962]: {"level":"info","ts":1616145604.2048814,"caller":"app/plugin.go:303","msg":"Shutting down plugins"}
Mar 19 09:20:04 systemd[1]: Stopping Mattermost...
Mar 19 09:20:04 mattermost[962]: {"level":"info","ts":1616145604.229865,"caller":"jobs/workers.go:270","msg":"Stopped workers"}
Mar 19 09:20:04 mattermost[962]: {"level":"info","ts":1616145604.2299707,"caller":"jobs/schedulers.go:160","msg":"Stopping schedulers."}
Mar 19 09:20:04 mattermost[962]: {"level":"info","ts":1616145604.230017,"caller":"jobs/schedulers.go:92","msg":"Schedulers stopped."}
Mar 19 09:20:04 mattermost[962]: {"level":"info","ts":1616145604.2305436,"caller":"app/server.go:845","msg":"Server stopped"}
Mar 19 09:20:04 systemd[1]: mattermost.service: Succeeded.
Mar 19 09:20:04 systemd[1]: Stopped Mattermost.
Mar 19 09:20:04 systemd[1]: Starting Mattermost...
Mar 19 09:20:04 mattermost[8486]: {"level":"info","ts":1616145604.733002,"caller":"app/server.go:226","msg":"Server is initializing...","go_version":"go1.14"}
Mar 19 09:20:04 mattermost[8486]: {"level":"info","ts":1616145604.7338126,"caller":"app/web_hub.go:83","msg":"Starting websocket hubs","number_of_hubs":4}
Mar 19 09:20:04 mattermost[8486]: {"level":"info","ts":1616145604.737171,"caller":"utils/i18n.go:91","msg":"Loaded system translations","for locale":"fr","from locale":"/var/www/mattermost/i18n/fr.json"}
Mar 19 09:20:04 mattermost[8486]: {"level":"info","ts":1616145604.7569275,"caller":"sqlstore/store.go:255","msg":"Pinging SQL","database":"master"}
Mar 19 09:20:05 mattermost[8486]: {"level":"info","ts":1616145604.9999325,"caller":"app/server.go:511","msg":"Current version is 5.32.1 (dev-linux-arm64-v5.32.1/Wed Feb 17 22:17:20 UTC 2021/8e4b90726ce863f46952ab8acf62ecb57438aa86/none)","current_version":"5.32.1","build_number":"dev-linux-arm64-v5.32.1","build_date":"Wed Feb 17 22:17:20 UTC 2021","build_hash":"8e4b90726ce863f46952ab8acf62ecb57438aa86","build_hash_enterprise":"none"}
Mar 19 09:20:05 mattermost[8486]: {"level":"info","ts":1616145605.0000436,"caller":"app/server.go:522","msg":"Team Edition Build","enterprise_build":false}
Mar 19 09:20:05 mattermost[8486]: {"level":"info","ts":1616145605.0000923,"caller":"app/server.go:526","msg":"Printing current working","directory":"/var/www/mattermost"}
Mar 19 09:20:05 mattermost[8486]: {"level":"info","ts":1616145605.0001457,"caller":"app/server.go:527","msg":"Loaded config","source":"file:///var/www/mattermost/config/config.json"}
Mar 19 09:20:05 mattermost[8486]: {"level":"info","ts":1616145605.0199456,"caller":"bleveengine/bleve.go:295","msg":"UpdateConf Bleve"}
Mar 19 09:20:05 mattermost[8486]: {"level":"info","ts":1616145605.1017828,"caller":"app/server.go:950","msg":"Starting Server..."}
Mar 19 09:20:05 mattermost[8486]: {"level":"info","ts":1616145605.1027718,"caller":"app/server.go:1027","msg":"Server is listening on 127.0.0.1:8065","address":"127.0.0.1:8065"}
Mar 19 09:20:05 mattermost[8486]: {"level":"info","ts":1616145605.1032257,"caller":"commands/server.go:117","msg":"Sending systemd READY notification."}
Mar 19 09:20:05 systemd[1]: Started Mattermost.
Mar 19 09:20:22 mattermost[8486]: {"level":"info","ts":1616145622.705041,"caller":"mlog/log.go:218","msg":"Starting up plugins"}
Mar 19 09:20:22 mattermost[8486]: {"level":"info","ts":1616145622.7051804,"caller":"app/plugin.go:226","msg":"Syncing plugins from the file store"}
Mar 19 09:20:22 mattermost[8486]: {"level":"info","ts":1616145622.7365327,"caller":"app/plugin.go:286","msg":"Syncing plugin from file store","bundle":"plugins/jitsi.tar.gz"}
Mar 19 09:20:22 mattermost[8486]: {"level":"info","ts":1616145622.7365413,"caller":"app/plugin.go:286","msg":"Syncing plugin from file store","bundle":"plugins/com.mattermost.plugin-todo.tar.gz"}
Mar 19 09:20:24 mattermost[8486]: {"level":"error","ts":1616145624.8360932,"caller":"app/plugin.go:288","msg":"Failed to sync plugin from file store","bundle":"plugins/jitsi.tar.gz","error":"installExtractedPlugin: Unable to restart plugin on upgrade., unable to start plugin: jitsi: fork/exec plugins/jitsi: permission denied"}
Mar 19 09:20:24 mattermost[8486]: {"level":"error","ts":1616145624.9380643,"caller":"app/plugin.go:288","msg":"Failed to sync plugin from file store","bundle":"plugins/com.mattermost.plugin-todo.tar.gz","error":"installExtractedPlugin: Unable to restart plugin on upgrade., unable to start plugin: com.mattermost.plugin-todo: fork/exec plugins/com.mattermost.plugin-todo: permission denied"}
Mar 19 09:20:25 mattermost[8486]: {"level":"error","ts":1616145625.178744,"caller":"mlog/log.go:232","msg":"Unable to activate plugin","plugin_id":"jitsi","error":"unable to start plugin: jitsi: fork/exec plugins/jitsi: permission denied","errorVerbose":"fork/exec plugins/jitsi: permission denied\nunable to start plugin: jitsi\ngithub.com/mattermost/mattermost-server/v5/plugin.(*Environment).Activate\n\tgithub.com/mattermost/mattermost-server/v5/plugin/environment.go:268\ngithub.com/mattermost/mattermost-server/v5/app.(*App).SyncPluginsActiveState.func2\n\tgithub.com/mattermost/mattermost-server/v5/app/plugin.go:132\nruntime.goexit\n\truntime/asm_arm64.s:1148"}
Mar 19 09:20:25 mattermost[8486]: {"level":"error","ts":1616145625.178918,"caller":"mlog/log.go:232","msg":"Unable to activate plugin","plugin_id":"com.mattermost.plugin-todo","error":"unable to start plugin: com.mattermost.plugin-todo: fork/exec plugins/com.mattermost.plugin-todo: permission denied","errorVerbose":"fork/exec plugins/com.mattermost.plugin-todo: permission denied\nunable to start plugin: com.mattermost.plugin-todo\ngithub.com/mattermost/mattermost-server/v5/plugin.(*Environment).Activate\n\tgithub.com/mattermost/mattermost-server/v5/plugin/environment.go:268\ngithub.com/mattermost/mattermost-server/v5/app.(*App).SyncPluginsActiveState.func2\n\tgithub.com/mattermost/mattermost-server/v5/app/plugin.go:132\nruntime.goexit\n\truntime/asm_arm64.s:1148"}
Mar 19 09:20:25 mattermost[8486]: {"level":"info","ts":1616145625.179654,"caller":"jobs/workers.go:98","msg":"Starting workers"}
Mar 19 09:20:25 mattermost[8486]: {"level":"info","ts":1616145625.1807325,"caller":"jobs/schedulers.go:89","msg":"Starting schedulers."}
Mar 19 09:20:25 mattermost[8486]: {"level":"info","ts":1616145625.1880112,"caller":"app/license.go:67","msg":"License key from https://mattermost.com required to unlock enterprise features."}
Mar 19 09:20:32 mattermost[8486]: {"level":"info","ts":1616145632.4936903,"caller":"sqlstore/post_store.go:1853","msg":"Post.Message has size restrictions","max_characters":16383,"max_bytes":65535}
Mar 19 09:20:32 mattermost[8486]: {"level":"info","ts":1616145632.4967363,"caller":"bleveengine/bleve.go:295","msg":"UpdateConf Bleve"}
Mar 19 09:20:32 mattermost[8486]: {"level":"error","ts":1616145632.8727527,"caller":"mlog/log.go:232","msg":"Unable to activate plugin","plugin_id":"com.mattermost.plugin-todo","error":"unable to start plugin: com.mattermost.plugin-todo: fork/exec plugins/com.mattermost.plugin-todo: permission denied","errorVerbose":"fork/exec plugins/com.mattermost.plugin-todo: permission denied\nunable to start plugin: com.mattermost.plugin-todo\ngithub.com/mattermost/mattermost-server/v5/plugin.(*Environment).Activate\n\tgithub.com/mattermost/mattermost-server/v5/plugin/environment.go:268\ngithub.com/mattermost/mattermost-server/v5/app.(*App).SyncPluginsActiveState.func2\n\tgithub.com/mattermost/mattermost-server/v5/app/plugin.go:132\nruntime.goexit\n\truntime/asm_arm64.s:1148"}
Mar 19 09:20:32 mattermost[8486]: {"level":"error","ts":1616145632.8862858,"caller":"mlog/log.go:232","msg":"Unable to activate plugin","plugin_id":"com.mattermost.plugin-todo","error":"unable to start plugin: com.mattermost.plugin-todo: fork/exec plugins/com.mattermost.plugin-todo: permission denied","errorVerbose":"fork/exec plugins/com.mattermost.plugin-todo: permission denied\nunable to start plugin: com.mattermost.plugin-todo\ngithub.com/mattermost/mattermost-server/v5/plugin.(*Environment).Activate\n\tgithub.com/mattermost/mattermost-server/v5/plugin/environment.go:268\ngithub.com/mattermost/mattermost-server/v5/app.(*App).SyncPluginsActiveState.func2\n\tgithub.com/mattermost/mattermost-server/v5/app/plugin.go:132\nruntime.goexit\n\truntime/asm_arm64.s:1148"}
Mar 19 09:20:35 mattermost[8486]: {"level":"info","ts":1616145635.2910535,"caller":"bleveengine/bleve.go:295","msg":"UpdateConf Bleve"}
Mar 19 09:20:35 mattermost[8486]: {"level":"error","ts":1616145635.6265264,"caller":"mlog/log.go:232","msg":"Unable to activate plugin","plugin_id":"jitsi","error":"unable to start plugin: jitsi: fork/exec plugins/jitsi: permission denied","errorVerbose":"fork/exec plugins/jitsi: permission denied\nunable to start plugin: jitsi\ngithub.com/mattermost/mattermost-server/v5/plugin.(*Environment).Activate\n\tgithub.com/mattermost/mattermost-server/v5/plugin/environment.go:268\ngithub.com/mattermost/mattermost-server/v5/app.(*App).SyncPluginsActiveState.func2\n\tgithub.com/mattermost/mattermost-server/v5/app/plugin.go:132\nruntime.goexit\n\truntime/asm_arm64.s:1148"}
Mar 19 09:20:35 mattermost[8486]: {"level":"error","ts":1616145635.6306155,"caller":"mlog/log.go:232","msg":"Unable to activate plugin","plugin_id":"com.mattermost.plugin-todo","error":"unable to start plugin: com.mattermost.plugin-todo: fork/exec plugins/com.mattermost.plugin-todo: permission denied","errorVerbose":"fork/exec plugins/com.mattermost.plugin-todo: permission denied\nunable to start plugin: com.mattermost.plugin-todo\ngithub.com/mattermost/mattermost-server/v5/plugin.(*Environment).Activate\n\tgithub.com/mattermost/mattermost-server/v5/plugin/environment.go:268\ngithub.com/mattermost/mattermost-server/v5/app.(*App).SyncPluginsActiveState.func2\n\tgithub.com/mattermost/mattermost-server/v5/app/plugin.go:132\nruntime.goexit\n\truntime/asm_arm64.s:1148"}
Mar 19 09:20:35 mattermost[8486]: {"level":"error","ts":1616145635.6479757,"caller":"mlog/log.go:232","msg":"Unable to activate plugin","plugin_id":"jitsi","error":"unable to start plugin: jitsi: fork/exec plugins/jitsi: permission denied","errorVerbose":"fork/exec plugins/jitsi: permission denied\nunable to start plugin: jitsi\ngithub.com/mattermost/mattermost-server/v5/plugin.(*Environment).Activate\n\tgithub.com/mattermost/mattermost-server/v5/plugin/environment.go:268\ngithub.com/mattermost/mattermost-server/v5/app.(*App).SyncPluginsActiveState.func2\n\tgithub.com/mattermost/mattermost-server/v5/app/plugin.go:132\nruntime.goexit\n\truntime/asm_arm64.s:1148"}
Mar 19 09:20:35 mattermost[8486]: {"level":"error","ts":1616145635.648648,"caller":"mlog/log.go:232","msg":"Unable to activate plugin","plugin_id":"com.mattermost.plugin-todo","error":"unable to start plugin: com.mattermost.plugin-todo: fork/exec plugins/com.mattermost.plugin-todo: permission denied","errorVerbose":"fork/exec plugins/com.mattermost.plugin-todo: permission denied\nunable to start plugin: com.mattermost.plugin-todo\ngithub.com/mattermost/mattermost-server/v5/plugin.(*Environment).Activate\n\tgithub.com/mattermost/mattermost-server/v5/plugin/environment.go:268\ngithub.com/mattermost/mattermost-server/v5/app.(*App).SyncPluginsActiveState.func2\n\tgithub.com/mattermost/mattermost-server/v5/app/plugin.go:132\nruntime.goexit\n\truntime/asm_arm64.s:1148"}
Mar 19 09:30:40 mattermost[8486]: {"level":"info","ts":1616146240.3396077,"caller":"expirynotify/worker.go:85","msg":"Worker: Job is complete","worker":"ExpiryNotify","job_id":"
hello, i do a new installation, and the log says :
{“level”:“info”,“ts”:1616838715.9338293,“caller”:“bleveengine/bleve.go:295”,“msg”:“UpdateConf Bleve”} {“level”:“info”,“ts”:1616838715.9399438,“caller”:“app/migrations.go:26”,“msg”:“Migrating roles to database.”} “level”:“error”,“ts”:1616838716.0559983,“caller”:“app/migrations.go:68”,“msg”:“Failed to update config in Advanced Permissions Phase 1 Migration.”,“error”:“saveConfig: An error occurred saving the configuration., configuration store is read-only”}
This means that your file permissions don’t have the ability to write to the file. It is read only at the moment. Are you on a Linux operating system?
hello, yes, on Debian
Alright, and do you have root command line access, and is your Mattermost installation in the /opt/mattermost/ directory, as it instructs you to do in the installation documentation?
hello, i grant write permissions to my files in /var/www/mattermost (i have a yunohost session server), but i have the same problem
Hi, @axac
Can you locate the /config/config.json file on your installation? I am not entirely sure how Yunohost session works (I believe you referred to GitHub - YunoHost-Apps/mattermost_ynh: Mattermost package for YunoHost) but if you can locate that file, we can check the current permission set on that folder and the file as well.
I think you may want to check and see my response on the Mattermost community server, however I will also include the same thing here (Note that you mentioned your using ARM 7 in your message on the community forum, while you didn’t on here)
Ahhh yes the issue would be that you are using ARM 7, which is an officially unsupported operating system. I would suggest looking at this Mattermost Raspberry Pi Recipe, which while being unofficial, seems like it works. I used a different version when I ran a Mattermost instance on a cluster of Raspberry PI’s a while back, but it was from a different location, and had a lot of bugs and issues with the conversion, so hopefully this one will work a lot better.
Sorry, i’m using ARM 64 (freebox delta, its an french internet box), i’m on a VM (debian 10) in my home.
Thanks for your post.
I hope ARM64 (for plugins) was natively supported in the futur.
Perhaps this : conf: update arm and arm64 to mattermost 5.32.1 by kemenaran · Pull Request #223 · YunoHost-Apps/mattermost_ynh · GitHub
I would suggest opening a Feature Request officially with the Mattermost team. Once it receives enough votes, the team would then make it a priority to actually integrate into the platform. You can access the Feature Request platform here.
thanks, good idea.
post
