doPermissionsMigration: The role was not valid after upgrade to release-11.6
I’m running Mattermost Team edition within Docker and have been tracking release-11 until today when watchtower did an upgrade to 11.6 and the service stopped starting. This is a relatively new install (about 3 weeks) so shouldn’t have too much “legacy” stuff knocking around.
The fatal error being logged is:
{"timestamp":"2026-05-13 13:06:45.815 Z","level":"fatal","msg":"Failed to run app migration","caller":"app/migrations.go:882","migration":"Permissions Migrations","error":"doPermissionsMigration: The role was not valid., invalid input: entity: Role field: <any> value: &{3uxwdr8h53fumrrnwk755cf1tc system_admin authentication.roles.global_admin.name authentication.roles.global_admin.description 1776157497755 1776498735184 0 [manage_others_outgoing_webhooks sysconsole_read_site_announcement_banner join_private_teams create_elasticsearch_post_indexing_job sysconsole_read_authentication_ldap order_bookmark_private_channel sysconsole_read_authentication_openid playbook_private_view manage_team_access_rules sysconsole_write_user_management_teams edit_post sysconsole_read_compliance_data_retention_policy delete_bookmark_private_channel manage_license_information create_group_channel sysconsole_read_integrations_bot_accounts use_group_mentions manage_others_bots manage_private_channel_banner manage_ldap_sync_job read_license_information sysconsole_read_environment_mobile_security sysconsole_read_experimental_features sysconsole_write_site_users_and_teams delete_private_channel sysconsol..."}
I’ve downgraded to release-11.5 and it’s starting up ok now.
I’m using the pattern described in Deploy Mattermost using Containers - Mattermost documentation using Docker without a Proxy (I have Caddy in place instead).
  • Postgres 18 (Alpine) as per Docker deployment guide
  • Running within an Alpine 3.23 VM on x86_64
  • Working image: mattermost/mattermost-team-edition:release-11.5 afb9ff161421
  • Broken image: mattermost/mattermost-team-edition:release-11 34495e89ac5c
Any hints…?
Thanks for the report, @fooflington! I’ve replied to your post on Mattermost with a follow up, namely a hope you can help us root cause what went wrong by sharing this from your instance:
SELECT name, permissions FROM roles WHERE name = 'system_admin';
I’ve filed Jira to track next steps once we know more.
This was sorted via MatterMost Community and is reportedly an issue with downgrade compatability issues. It was fixed by upgrading to release-11.7
With thanks to @jesse for his help!
