I’m upgrading from mattermost enterprise 9 to latest 9.5.1. I previosly migrate from 6 to 7, and from 7 to 9 directly. All works fine, but focalboard plugin. I don’t know why, when I create any resource, property, message, anything, I see error 500 in server, with following message:
{“timestamp”:“2024-02-26 15:51:08.525 Z”,“level”:“error”,“msg”:“API ERROR”,“caller”:“app/plugin_api.go:1003”,“plugin_id”:“focalboard”,“code”:“500”,“error”:“"Error 1062 (23000): Duplicate entry ‘vnxbebs4eyiy7dq8tptrpcjajor-0000-00-00 00:00:00.000000’ for key ‘focalboard_blocks_history.PRIMARY’"”,“api”:“/api/v2/boards/bok76ntnoxpbyijxxw6m6xa3tny/blocks/vnxbebs4eyiy7dq8tptrpcjajor”}
{“timestamp”:“2024-02-26 15:51:44.371 Z”,“level”:“error”,“msg”:“Error 1062 (23000): Duplicate entry ‘vnxbebs4eyiy7dq8tptrpcjajor-0000-00-00 00:00:00.000000’ for key ‘focalboard_blocks_history.PRIMARY’”,“caller”:“app/plugin_api.go:1003”,“plugin_id”:“focalboard”}
{“timestamp”:“2024-02-26 15:51:44.372 Z”,“level”:“error”,“msg”:“API ERROR”,“caller”:“app/plugin_api.go:1003”,“plugin_id”:“focalboard”,“code”:“500”,“error”:“"Error 1062 (23000): Duplicate entry ‘vnxbebs4eyiy7dq8tptrpcjajor-0000-00-00 00:00:00.000000’ for key ‘focalboard_blocks_history.PRIMARY’"”,“api”:“/api/v2/boards/bok76ntnoxpbyijxxw6m6xa3tny/blocks/vnxbebs4eyiy7dq8tptrpcjajor”}
Can anyone help me?
Thank you all.
