- Is it possible to have global search of the header as well as content of discussion even though the person who is searching it is not part of any channels ?
- How to remove member from specific channel ?How to merge two channels if both the channels are discussing about same thing ?
- How to search via Last feed ? Means what is last feed for particular channel how to get it ?
- What is the Maximum file size that can be attached ?
- What is Database used to store ?
- If its MYSQL is there any service exposed to get the records ?
- If I want to change some functionality will it be possible ?
Regarding the question “How to merge two channels”, the best advice I’ve found is old and is here:
tarek : )
