Hi all,
Here is my trouble when I try to login Mattermot with Gitlab account.
Error
Token request failed
[Back to GitLab Mattermost](https://mattermost.xxx.vn/)
Show on logs:
==> /var/log/gitlab/mattermost/mattermost.log <==
{“level”:“error”,“ts”:1580810926.2013972,“caller”:“web/oauth.go:259”,“msg”:“AuthorizeOAuthUser: Token request failed, Post http://gitlab.supremetech.vn/oauth/token: dial tcp 54.210.131.230:80: i/o timeout”}
==> /var/log/gitlab/mattermost/current <==
2020-02-04_10:08:46.20147 {"level":"error","ts":1580810926.2013972,"caller":"web/oauth.go:259","msg":"AuthorizeOAuthUser: Token request failed, Post http://gitlab.supremetech.vn/oauth/token: dial tcp 54.210.131.230:80: i/o timeout"}
On AWS, Create instance t2.medium with Amazonlinux 2 image. Create Application Loadbalancer (Listener port80 and port443)
User docker-compose to start service, here is docker-compose file content:
version: “3.7”
services:
# db:
# restart: always
# image: postgres:12.1
# container_name: “db”
# volumes:
# # Mount EFS volume
# - /home/ec2-user/efs/gitlab/db/data:/var/lib/postgresql/data:Z
# - /etc/localtime:/etc/localtime:ro
# environment:
# - POSTGRES_USER=gitlab
# - POSTGRES_PASSWORD=pASsw0rd
# - POSTGRES_DB=st_gitlab_production
# ports:
# - “5432:5432”gitlab: container_name: gitlab image: "gitlab/gitlab-ce:12.5.9-ce.0" restart: always #hostname: "gitlab.supremetech.vn" environment: GITLAB_OMNIBUS_CONFIG: | # Gitlab basic configuration letsencrypt['enable'] = false letsencrypt['contact_emails'] = ['gitlab@example.com'] external_url 'https://gitlab.supremetech.vn' # Prevent GitLab from starting if NFS data mounts are not available (not working for docker) # high_availability['mountpoint'] = '/var/opt/gitlab/git-data' # Ensure UIDs and GIDs match between servers for permissions via NFS user['uid'] = 9000 user['gid'] = 9000 web_server['uid'] = 9001 web_server['gid'] = 9001 registry['uid'] = 9002 registry['gid'] = 9002 # gitlab_rails['registry_enabled'] = false gitlab_rails['time_zone'] = 'Asia/Ho_Chi_Minh' gitlab_rails['lfs_enabled'] = true gitlab_rails['initial_root_password'] = 'root@!2vWzOb15u' gitlab_rails['gitlab_shell_ssh_port'] = 2224 # Change URL for clone via SSH gitlab_rails['gitlab_ssh_host'] = 'gitlab-ssh.supremetech.vn' # OmniAuth Configuration gitlab_rails['omniauth_enabled'] = true gitlab_rails['omniauth_external_providers'] = ['saml'] gitlab_rails['omniauth_allow_single_sign_on'] = ['saml'] gitlab_rails['omniauth_sync_email_from_provider'] = 'saml' gitlab_rails['omniauth_block_auto_created_users'] = false gitlab_rails['omniauth_auto_link_ldap_user'] = false gitlab_rails['omniauth_sync_profile_from_provider'] = ['saml'] gitlab_rails['omniauth_sync_profile_attributes'] = ['email'] gitlab_rails['omniauth_auto_link_saml_user'] = true # Uncomment this once you 100% ready to use SSO # gitlab_rails['omniauth_auto_sign_in_with_provider'] = 'saml' gitlab_rails['omniauth_providers'] = [ { # G-Suite 'name': 'saml', 'args': { 'assertion_consumer_service_url': 'https://gitlab.supremetech.vn/users/auth/saml/callback', 'idp_cert_fingerprint': '6F:EB:CA:49:7E:2A:0F:7F:AE:F6:81:89:D5:74:45:C2:54:EB:49:8C', 'idp_sso_target_url': 'https://accounts.google.com/o/saml2/idp?idpid=C04iisy27', 'issuer': 'https://gitlab.supremetech.vn', 'name_identifier_format': 'urn:oasis:names:tc:SAML:1.1:nameid-format:emailAddress', 'attribute_statements': { 'email': ['emailAddress'] } }, 'label': 'G Suite' } ] # Email Settings gitlab_rails['gitlab_email_from'] = 'bach@supremetech.vn' gitlab_rails['gitlab_email_display_name'] = 'Gitlab Supremetech' gitlab_rails['gitlab_email_reply_to'] = 'bach@supremetech.vn' gitlab_rails['gitlab_email_subject_suffix'] = 'Example GitLab' # Disable the built-in Postgres postgresql['enable'] = false # Recommend value is 1/4 of total RAM, up to 14GB. postgresql['shared_buffers'] = '2GB' # PostgreSQl database configuration gitlab_rails['db_adapter'] = 'postgresql' gitlab_rails['db_encoding'] = 'utf8' gitlab_rails['db_host'] = 'write.db.local' gitlab_rails['db_port'] = 5432 gitlab_rails['db_database'] = 'st_gitlab_production' gitlab_rails['db_username'] = 'master' gitlab_rails['db_password'] = 'pASsw0rd' # Gmail SMTP configuration gitlab_rails['smtp_enable'] = true gitlab_rails['smtp_address'] = 'smtp.gmail.com' gitlab_rails['smtp_port'] = 587 gitlab_rails['smtp_user_name'] = 'bach@supremetech.vn' gitlab_rails['smtp_password'] = 'kuwqxahgbxlvmytl' gitlab_rails['smtp_domain'] = 'smtp.gmail.com' gitlab_rails['smtp_authentication'] = 'login' gitlab_rails['smtp_enable_starttls_auto'] = true gitlab_rails['smtp_tls'] = false gitlab_rails['smtp_openssl_verify_mode'] = 'peer' # Nginx config nginx['redirect_http_to_https'] = false # Fix git clone https via ALB nginx['listen_port'] = 80 nginx['listen_https'] = false nginx['proxy_set_headers'] = { "X-Forwarded-Proto" => "https", "X-Forwarded-Ssl" => "on" } # MatterMost Configuration # mattermost['enable'] = true# gitlab-ce/config/gitlab.rb mattermost_external_url 'https://mattermost.supremetech.vn' mattermost['service_site_url'] = 'https://mattermost.supremetech.vn' # mattermost['service_use_ssl'] = false # # mattermost['service_use_ssl'] = true mattermost_nginx['listen_port'] = 80 mattermost_nginx['listen_https'] = false mattermost_nginx['proxy_set_headers'] = { 'X-Forwarded-Proto' => 'https', 'X-Forwarded-Ssl' => 'on' } # GitLab as the only external authentication source mattermost['email_enable_sign_up_with_email'] = false mattermost['email_enable_sign_in_with_email'] = false mattermost['email_enable_sign_in_with_username'] = false # Configure an e-mail address and SMTP server for Mattermost mattermost['email_send_email_notifications'] = true mattermost['email_require_email_verification'] = false mattermost['email_smtp_username'] = "bach@supremetech.vn" mattermost['email_smtp_password'] = "kuwqxahgbxlvmytl" mattermost['email_smtp_server'] = "smtp.gmail.com" mattermost['email_smtp_port'] = "587" # 587 mattermost['email_connection_security'] = 'TLS' # 'TLS', 'STARTTLS' or nil mattermost['email_feedback_name'] = "GitLab Mattermost" mattermost['email_feedback_email'] = "bach@supremetech.vn" # E-mail batching allowing users to control how often they receive notifications mattermost['email_enable_batching'] = true # Config DB for mattermost mattermost['sql_driver_name'] = 'postgres' mattermost['sql_data_source'] = "user=master host=write.db.local port=5432 dbname=mattermost password=pASsw0rd" # Gitlab Mattermost mattermost['gitlab_enable'] = true mattermost['gitlab_id'] = "86ef2661bbc88f59b6963e80b648b8c3ebdc8b4628342f28c14cebd5a6d449e3" mattermost['gitlab_secret'] = "cc41afff7dbff5c1dabcf207b78318b68bf1d117577c6bd3bb5b6ce2c13643d9" mattermost['gitlab_scope'] = "" mattermost['gitlab_auth_endpoint'] = "https://gitlab.supremetech.vn/oauth/authorize" mattermost['gitlab_token_endpoint'] = "https://gitlab.supremetech.vn/oauth/token" mattermost['gitlab_user_api_endpoint'] = "https://gitlab.supremetech.vn/api/v4/user" # fix token error mattermost['service_enable_insecure_outgoing_connections'] = true mattermost['uid'] = 1234 mattermost['gid'] = 1234 ports: - "80:80" - "443:443" - "2224:22" volumes: # Mount EFS volume - "/home/ec2-user/efs/gitlab/config:/etc/gitlab" - "/var/log/gitlab:/var/log/gitlab" - "/home/ec2-user/efs/gitlab/data:/var/opt/gitlab" -
run: docker-compose up -d
Homepage of mattermost:
Screenshot by Lightshot
After click Gitlab Signle Sign On:
https://prnt.sc/qxbl47
Describe your issue in detail
docker logs -f gitlab result:
==> /var/log/gitlab/mattermost/current <== 2020-02-04_09:47:29.77464 {"level":"info","ts":1580809649.7746255,"caller":"app/server.go:220","msg":"Loaded config","source":"file:///var/opt/gitlab/mattermost/config.json"} 2020-02-04_09:47:29.79643 {"level":"info","ts":1580809649.79637,"caller":"sqlstore/post_store.go:1356","msg":"Post.Message has size restrictions","max_characters":16383,"max_bytes":65535} 2020-02-04_09:47:29.86422 {"level":"info","ts":1580809649.8641675,"caller":"jobs/workers.go:68","msg":"Starting workers"} 2020-02-04_09:47:29.86488 {"level":"info","ts":1580809649.8642733,"caller":"app/server.go:423","msg":"Starting Server..."} 2020-02-04_09:47:29.86489 {"level":"info","ts":1580809649.8643892,"caller":"app/server.go:489","msg":"Server is listening on 127.0.0.1:8065"} 2020-02-04_09:47:29.86579 {"level":"info","ts":1580809649.8657637,"caller":"jobs/schedulers.go:72","msg":"Starting schedulers."} 2020-02-04_09:47:29.87263 {"level":"info","ts":1580809649.8725827,"caller":"app/web_hub.go:75","msg":"Starting 4 websocket hubs"} 2020-02-04_09:47:29.87348 {"level":"error","ts":1580809649.8732216,"caller":"web/static.go:26","msg":"Failed to update assets subpath from config","error":"failed to update root.html with subpath /: open /opt/gitlab/embedded/service/mattermost/client/root.html: permission denied","errorVerbose":"open /opt/gitlab/embedded/service/mattermost/client/root.html: permission denied\nfailed to update root.html with subpath /\ngithub.com/mattermost/mattermost-server/utils.UpdateAssetsSubpath\n\t/go/src/github.com/mattermost/mattermost-server/utils/subpath.go:117\ngithub.com/mattermost/mattermost-server/utils.UpdateAssetsSubpathFromConfig\n\t/go/src/github.com/mattermost/mattermost-server/utils/subpath.go:156\ngithub.com/mattermost/mattermost-server/web.(*Web).InitStatic\n\t/go/src/github.com/mattermost/mattermost-server/web/static.go:25\ngithub.com/mattermost/mattermost-server/web.New\n\t/go/src/github.com/mattermost/mattermost-server/web/web.go:39\ngithub.com/mattermost/mattermost-server/cmd/mattermost/commands.runServer\n\t/go/src/github.com/mattermost/mattermost-server/cmd/mattermost/commands/server.go:83\ngithub.com/mattermost/mattermost-server/cmd/mattermost/commands.serverCmdF\n\t/go/src/github.com/mattermost/mattermost-server/cmd/mattermost/commands/server.go:53\ngithub.com/spf13/cobra.(*Command).execute\n\t/go/src/github.com/mattermost/mattermost-server/vendor/github.com/spf13/cobra/command.go:826\ngithub.com/spf13/cobra.(*Command).ExecuteC\n\t/go/src/github.com/mattermost/mattermost-server/vendor/github.com/spf13/cobra/command.go:914\ngithub.com/spf13/cobra.(*Command).Execute\n\t/go/src/github.com/mattermost/mattermost-server/vendor/github.com/spf13/cobra/command.go:864\ngithub.com/mattermost/mattermost-server/cmd/mattermost/commands.Run\n\t/go/src/github.com/mattermost/mattermost-server/cmd/mattermost/commands/root.go:15\nmain.main\n\t/go/src/github.com/mattermost/mattermost-server/cmd/mattermost/main.go:30\nruntime.main\n\t/usr/local/go/src/runtime/proc.go:200\nruntime.goexit\n\t/usr/local/go/src/runtime/asm_amd64.s:1337"} 2020-02-04_09:51:50.54255 {"level":"error","ts":1580809910.542492,"caller":"web/oauth.go:259","msg":"AuthorizeOAuthUser: Token request failed, Post http://gitlab.xxx.xxx/oauth/token: dial tcp 34.226.43.157:80: i/o timeout"} 2020-02-04_09:54:22.49820 {"level":"error","ts":1580810062.4981291,"caller":"web/oauth.go:259","msg":"AuthorizeOAuthUser: Token request failed, Post http://gitlab.xxx.xxx/oauth/token: dial tcp 54.210.131.230:80: i/o timeout"} ==> /var/log/gitlab/mattermost/mattermost.log <== {"level":"error","ts":1580810824.368601,"caller":"web/oauth.go:259","msg":"AuthorizeOAuthUser: Token request failed, Post http://gitlab.xxx.xxx/oauth/token: dial tcp 54.210.131.230:80: i/o timeout"} ==> /var/log/gitlab/mattermost/current <== 2020-02-04_10:07:04.36868 {"level":"error","ts":1580810824.368601,"caller":"web/oauth.go:259","msg":"AuthorizeOAuthUser: Token request failed, Post http://gitlab.xxx.xxx/oauth/token: dial tcp 54.210.131.230:80: i/o timeout"} ==> /var/log/gitlab/mattermost/mattermost.log <== {"level":"error","ts":1580810926.2013972,"caller":"web/oauth.go:259","msg":"AuthorizeOAuthUser: Token request failed, Post http://gitlab.xxx.xxx/oauth/token: dial tcp 54.210.131.230:80: i/o timeout"} ==> /var/log/gitlab/mattermost/current <== 2020-02-04_10:08:46.20147 {"level":"error","ts":1580810926.2013972,"caller":"web/oauth.go:259","msg":"AuthorizeOAuthUser: Token request failed, Post http://gitlab.xxx.xxx/oauth/token: dial tcp 54.210.131.230:80: i/o timeout"} ==> /var/log/gitlab/mattermost/mattermost.log <== {"level":"error","ts":1580813729.111235,"caller":"web/oauth.go:259","msg":"AuthorizeOAuthUser: Token request failed, Post http://gitlab.xxx.xxx/oauth/token: dial tcp 54.210.131.230:80: i/o timeout"} ==> /var/log/gitlab/mattermost/current <== 2020-02-04_10:55:29.11131 {"level":"error","ts":1580813729.111235,"caller":"web/oauth.go:259","msg":"AuthorizeOAuthUser: Token request failed, Post http://gitlab.xxx.xxx/oauth/token: dial tcp 54.210.131.230:80: i/o timeout"}
