How can we load the mattermost in Iframe. We have to Inbuilt the mattermost in to our application.
Is there any settings we have to enable?
Mattermost has code to prevent the application from being contained in an iframe to avoid āclickjackingā where a malicious user contains the app in an iframe to steal user data. Containing the application within an iframe is not recommended.
Just to follow up to the Q&A, if using IFrame is not recommended what is the recommended way to seamlessly integrate Mattermost inside an existing web application?
Hi @gosure,
Thereās currently a feature idea submitted to add the ability to integrate Mattermost into other websites.
Each release cycle feature ideas are consideredāwith community upvotes and comments playing a role significant role in prioritization.
If you feel the existing feature idea aligns with your needs, please upvote? Alternatively, if you have a different need, please share a new idea, so the community can upvote the use case?
I have successfully (it appears) embedded Mattermost in an iframe. I run the Mattermost Docker image with a nginx reverse proxy in front.
Be aware that by doing this you are decreasing the level of security of your site.
Mattermost uses a set of HTTP headers in addition to a JavaScript trick to prevent embedding/clickjacking.
In nginx I strip out the two relevant HTTP headers:
location / {
# Disable gzip due to https://bugs.debian.org/773332
gzip off;
# Enable WebSockets:
proxy_pass http://localhost:8065/;
include /etc/nginx/proxy_params;
# Mattermost does not allow embedding by default, so we strip out the header that restricts it:
proxy_hide_header Content-Security-Policy;
proxy_hide_header X-Frame-Options;
The JavaScript is located in the /mattermost/mattermost/web/templates/head.html file.
Somewhat early in the file there is a snippet
<style id=āantiClickjackā>body{display:none !important;}</style>
Comment that out by adding <!-- and --> around it and you should be good!
I canāt find head.html.
Iām running mattermost on a debian/apache2 server.
They only reference to antiClickjack is found in the file
ā/opt/mattermost/webapp/dist/52.2ebba305a3f129d699b9.jsā and it seems a bit messy to fool around it.
There is an option in apache (security.conf), with mod_headers enabled.
Iām gonna try it, but I have low expectation since mattermost java code calls for an āantiClickjackā object.
Otherwise, in the source code, I found something interesting in ./api/files.go
Here are the lines 522-541
func writeFileResponse(filename string, contentType string, bytes byte, w http.ResponseWriter, r *http.Request) *mo
del.AppError {
w.Header().Set(āCache-Controlā, āmax-age=2592000, publicā)
w.Header().Set(āContent-Lengthā, strconv.Itoa(len(bytes)))
if contentType != "" { w.Header().Set("Content-Type", contentType) } else { w.Header().Del("Content-Type") // Content-Type will be set automatically by the http writer }
w.Header().Set("Content-Disposition", "attachment;filename=\""+filename+"\"; filename*=UTF-8''"+url.QueryEscape(filename))
// prevent file links from being embedded in iframes w.Header().Set("X-Frame-Options", "DENY") w.Header().Set("Content-Security-Policy", "Frame-ancestors 'none'")
w.Write(bytes)
return nil
For your info, there was a pull request about that.
it seems that head.html no longer exists. The header to disable embedding MM in an iframe was added in ./api/context.go
See the pull request:
https://github.com/mattermost/platform/pull/253
I have added a feature idea to parametrize the clickjacking protection, so that you can disable it for a specific site when you want mattermost to be integrated in an iframe of these site:
Any plans to add a printscreen?
What is the current status of this since the documentation states to change the āhead.htmlā which is nonexistent since a few years. The file ācontext.goā seems nowhere to be found aswell. Is there any legit way to do this and is the documentation 4 years old and completely wrong?!
Hello
I have exactly the same problem. The index.html, context.go files do not exist. Is there a solution ?
I created a github issue and created asupport ticket. Both did not yield any success yet
Hi everyone and @Gunny,
Iāve tried to embed Mattermost into my Nextcloud Instance so Iāve tried to follow the instruction from here:
https://docs.mattermost.com/install/install-ubuntu-1804.html#configuration-nginx-as-a-proxy-for-mattermost-server
But I canāt find the path ( /etc/nginx/sites-available/) to nginx from my container.
Here what I have behond āetcā:
My Mattermost Instance is on a Synology NAS behind reverse proxy.
Does somebody has a solution or has already did it and can help me?
