1. I am trying to develop setup for desktop, but struck with multiple issues. as per this documentation Developer setup
npm i is always failing with some exception - attached log file
2. build and cli commands also not working
C:\Jio\Repo\mattermost-desktop>npm run clean
‘rm’ is not recognized as an internal or external command,
operable program or batch file.
3. How do I change .pfx file to our’s
Log
3665 timing reify:rollback:createSparse Completed in 54927ms
3666 timing reify:rollback:retireShallow Completed in 16ms
3667 timing command:i Completed in 263238ms
3668 verbose stack Error: command failed
3668 verbose stack at ChildProcess. (C:\Users\konda2.reddy\AppData\Roaming\npm\node_modules\npm\node_modules@npmcli\promise-spawn\lib\index.js:53:27)
3668 verbose stack at ChildProcess.emit (node:events:513:28)
3668 verbose stack at maybeClose (node:internal/child_process:1091:16)
3668 verbose stack at ChildProcess._handle.onexit (node:internal/child_process:302:5)
3669 verbose pkgid windows-focus-assist@1.3.0
3670 verbose cwd C:\Jio\Repo\mattermost-desktop
3671 verbose Windows_NT 10.0.19043
3672 verbose node v18.16.0
3673 verbose npm v9.4.1
3674 error code 1
3675 error path C:\Jio\Repo\mattermost-desktop\node_modules\windows-focus-assist
3676 error command failed
3677 error command C:\WINDOWS\system32\cmd.exe /d /s /c node-gyp rebuild
3678 error Building the projects in this solution one at a time. To enable parallel build, please add the “-m” switch.
3678 error
3678 error 64 bit Processing …\lib\quiethours.idl
3678 error quiethours.idl
3678 error 64 bit Processing C:\Program Files (x86)\Windows Kits\10\Include\10.0.22000.0\um\oaidl.idl
3678 error oaidl.idl
3678 error 64 bit Processing C:\Program Files (x86)\Windows Kits\10\Include\10.0.22000.0\um\objidl.idl
3678 error objidl.idl
3678 error 64 bit Processing C:\Program Files (x86)\Windows Kits\10\Include\10.0.22000.0\um\unknwn.idl
3678 error unknwn.idl
3678 error 64 bit Processing C:\Program Files (x86)\Windows Kits\10\Include\10.0.22000.0\shared\wtypes.idl
3678 error wtypes.idl
3678 error 64 bit Processing C:\Program Files (x86)\Windows Kits\10\Include\10.0.22000.0\shared\wtypesbase.idl
3678 error wtypesbase.idl
3678 error 64 bit Processing C:\Program Files (x86)\Windows Kits\10\Include\10.0.22000.0\shared\basetsd.h
3678 error basetsd.h
3678 error 64 bit Processing C:\Program Files (x86)\Windows Kits\10\Include\10.0.22000.0\shared\guiddef.h
3678 error guiddef.h
3678 error 64 bit Processing C:\Program Files (x86)\Windows Kits\10\Include\10.0.22000.0\um\oaidl.acf
3678 error oaidl.acf
3678 error focus-assist.cc
3678 error C:\Jio\Repo\mattermost-desktop\node_modules\windows-focus-assist\lib\focus-assist.cc(154,5): warning C4530: C++ exception handler used, but unwind semantics are not enabled. Specify /EHsc [C:\Jio\Repo\mattermost-desktop\node_modules\windows-focus-assist\build\focusassist.vcxproj]
3678 error quiethours_i.c
3678 error win_delay_load_hook.cc
3678 error LINK : fatal error LNK1104: cannot open file ‘atls.lib’ [C:\Jio\Repo\mattermost-desktop\node_modules\windows-focus-assist\build\focusassist.vcxproj]
3679 error gyp info it worked if it ends with ok
3679 error gyp info using node-gyp@9.3.0
3679 error gyp info using node@18.16.0 | win32 | x64
3679 error gyp info find Python using Python version 3.11.3 found at “C:\Python311\python.exe”
3679 error gyp info find VS using VS2022 (17.5.33424.131) found at:
3679 error gyp info find VS “C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools”
3679 error gyp info find VS run with --verbose for detailed information
3679 error gyp info spawn C:\Python311\python.exe
3679 error gyp info spawn args [
3679 error gyp info spawn args ‘C:\Jio\Repo\mattermost-desktop\node_modules\node-gyp\gyp\gyp_main.py’,
3679 error gyp info spawn args ‘binding.gyp’,
3679 error gyp info spawn args ‘-f’,
3679 error gyp info spawn args ‘msvs’,
3679 error gyp info spawn args ‘-I’,
3679 error gyp info spawn args ‘C:\Jio\Repo\mattermost-desktop\node_modules\windows-focus-assist\build\config.gypi’,
3679 error gyp info spawn args ‘C:\Jio\Repo\mattermost-desktop\node_modules\node-gyp\addon.gypi’,
3679 error gyp info spawn args ‘C:\Users\konda2.reddy\AppData\Local\node-gyp\Cache\18.16.0\include\node\common.gypi’,
3679 error gyp info spawn args ‘-Dlibrary=shared_library’,
3679 error gyp info spawn args ‘-Dvisibility=default’,
3679 error gyp info spawn args ‘-Dnode_root_dir=C:\Users\konda2.reddy\AppData\Local\node-gyp\Cache\18.16.0’,
3679 error gyp info spawn args ‘-Dnode_gyp_dir=C:\Jio\Repo\mattermost-desktop\node_modules\node-gyp’,
3679 error gyp info spawn args ‘-Dnode_lib_file=C:\\Users\\konda2.reddy\\AppData\\Local\\node-gyp\\Cache\\18.16.0\\<(target_arch)\\node.lib’,
3679 error gyp info spawn args ‘-Dmodule_root_dir=C:\Jio\Repo\mattermost-desktop\node_modules\windows-focus-assist’,
3679 error gyp info spawn args ‘-Dnode_engine=v8’,
3679 error gyp info spawn args ‘–depth=.’,
3679 error gyp info spawn args ‘–no-parallel’,
3679 error gyp info spawn args ‘–generator-output’,
3679 error gyp info spawn args ‘C:\Jio\Repo\mattermost-desktop\node_modules\windows-focus-assist\build’,
3679 error gyp info spawn args ‘-Goutput_dir=.’
3679 error gyp info spawn args ]
3679 error gyp info spawn C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\MSBuild\Current\Bin\MSBuild.exe
3679 error gyp info spawn args ‘build/binding.sln’,
3679 error gyp info spawn args ‘/clp:Verbosity=minimal’,
3679 error gyp info spawn args ‘/nologo’,
3679 error gyp info spawn args ‘/p:Configuration=Release;Platform=x64’
3679 error gyp ERR! build error
3679 error gyp ERR! stack Error: C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\MSBuild\Current\Bin\MSBuild.exe
failed with exit code: 1
3679 error gyp ERR! stack at ChildProcess.onExit (C:\Jio\Repo\mattermost-desktop\node_modules\node-gyp\lib\build.js:203:23)
3679 error gyp ERR! stack at ChildProcess.emit (node:events:513:28)
3679 error gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)
3679 error gyp ERR! System Windows_NT 10.0.19043
3679 error gyp ERR! command “C:\Program Files\nodejs\node.exe” “C:\Jio\Repo\mattermost-desktop\node_modules\node-gyp\bin\node-gyp.js” “rebuild”
3679 error gyp ERR! cwd C:\Jio\Repo\mattermost-desktop\node_modules\windows-focus-assist
3679 error gyp ERR! node -v v18.16.0
3679 error gyp ERR! node-gyp -v v9.3.0
3679 error gyp ERR! not ok
3680 verbose exit 1
3681 timing npm Completed in 263433ms
3682 verbose unfinished npm timer reify 1681985551322
3683 verbose unfinished npm timer reify:build 1681985737013
3684 verbose unfinished npm timer build 1681985737017
3685 verbose unfinished npm timer build:deps 1681985737018
3686 verbose unfinished npm timer build:run:install 1681985739011
3687 verbose unfinished npm timer build:run:install:node_modules/windows-focus-assist 1681985739061
3688 verbose code 1
3689 error A complete log of this run can be found in:
3689 error C:\Users\konda2.reddy\AppData\Local\npm-cache_logs\2023-04-20T10_12_31_159Z-debug-0.log
