The mmetl transform slack command is used to work around that when you specify the correct --team command line parameter. I really need to see the full output of the commands I’m asking for and also see the commands you entered in order to help you, it’s hard enough to diagnose such problems over the internet without access to the system…
What did your mmetl transform slack command look like and is this team already created in Mattermost? It needs to be there, the importer will not create the team.
I’m really not sure how i would show you the full output of the command it is HUGE and i tried copying and pasting and for some reason it is not doing that correctly.
to be honest i dont recall what the mmetl transform slack command looked like that was way too many commands ago and yest the team is already created in mattermost.
Give me a minute and i’ll attempt to somehow copy the full results of that last command
import validation error in “mattermost-bulk-import.zip”->“mattermost_import.jsonl”:1191 field “post.team”: reference to unknown team “slackimport”
[… repeated errors on different lines …]
import validation error in “mattermost-bulk-import.zip”->“mattermost_import.jsonl”:1291 field “post.team”: reference to unknown team “slackimport”
import validation error in “mattermost-bulk-import.zip”->“mattermost_import.jsonl”:1391 field “post.team”: reference to unknown team “slackimport”
this goes on for over 2,000 lines i can post them all if you want but i’ll try and point out anything unique:
import validation error in “mattermost-bulk-import.zip”->“mattermost_import.jsonl”:2142 field “post”: BulkImport: app.import.validate_post_import_data.message_length.error,
Schemes (0): []
Teams (0): []
Channels (35): [bankaccount, condo, deal-analysis-and-offer-sheets, ...]
Users (3): [user1, user2, slack_advanced_export]
Emojis (0): []
Posts (3141)
Direct Channels (0)
Attachments (557): [data/bulk-export-attachments/F01C6SPK1KR_Screenshot_20201014-193625_Chrome.jpg, data/bulk-export-attachments/F01CP5J5JTY_image.png, ...]
Unused Attachments (47):
data/bulk-export-attachments/F01KBV8JB26_image.png
data/bulk-export-attachments/F01KJ4QDQ4U_image.png
data/bulk-export-attachments/F01L1QEK8M6_Screenshot_20210120-155143_Chrome.jpg
data/bulk-export-attachments/F01L9A44MPY_image.png
data/bulk-export-attachments/F01LG9KUG03_image.png
data/bulk-export-attachments/F01LN8DAFJQ_image.png
data/bulk-export-attachments/F01M5UA4VA4_image.png
data/bulk-export-attachments/F01PER9JNNA_Screenshot_20210228-113035_Outlook.jpg
data/bulk-export-attachments/F020Z2KHBTQ_image.png
data/bulk-export-attachments/F0212P8PBTP_image.png
data/bulk-export-attachments/F02161Z6GE7_image.png
data/bulk-export-attachments/F023H3YTPC6_Wasabi2019.pdf
data/bulk-export-attachments/F023PSVH09Y_Revenue and Receipts Report for 560 2nd Ave. from 01-01-2021 to 06-01-2021.pdf
data/bulk-export-attachments/F023Q3RNQ67_Revenue and Receipts Report for 560 2nd Ave. from 01-01-2020 to 01-01-2021.pdf
data/bulk-export-attachments/F029FKPCTKQ_image.png
data/bulk-export-attachments/F02EZ13PXD3_JB-30169376.pdf
data/bulk-export-attachments/F02F21L65FC_JB-30169376 (1).pdf
data/bulk-export-attachments/F02F22B2M7D_image.png
data/bulk-export-attachments/F02F79A0L3H_Trinity Episcopal.docx
data/bulk-export-attachments/F02FK0PFHGV_Garry Sampson 144-96-34.docx
data/bulk-export-attachments/F02FN0X15KL_Pisenti.docx
data/bulk-export-attachments/F02GB0ZEHHD_Dunn County - 144-95-13.pdf
data/bulk-export-attachments/F02GBKEEX08_Garry Sampson 145-97-27,34,35.docx
data/bulk-export-attachments/F02GNMJR6TX_Dunn County - 144-96-34.pdf
data/bulk-export-attachments/F02H49S1H17_Dunn County - 144-97-26.pdf
data/bulk-export-attachments/F02J0HTBF0S_3.1 Deed
data/bulk-export-attachments/F02JHB1MC1E_30418957 - 1001005030.csv
data/bulk-export-attachments/F02U1DTNHN2_taFyqO-FTcTw-1-8.csv
data/bulk-export-attachments/F02U857EYN7_taFyqO-FTcTw-1-10.csv
data/bulk-export-attachments/F02U857GJD9_taFyqO-FTcTw-1-1.csv
data/bulk-export-attachments/F02UDFD2RD2_taFyqO-FTcTw-1-44.csv
data/bulk-export-attachments/F02ULP6NA3B_taFyqO-FTcTw-1-7.csv
data/bulk-export-attachments/F02ULP6Q1EV_taFyqO-FTcTw-1-9.csv
data/bulk-export-attachments/F02UPRCEMBK_taFyqO-FTcTw-1-56.csv
data/bulk-export-attachments/F033K3X927R_runs_1_13_combined.csv
data/bulk-export-attachments/F033T1AMZ4N_Chevron 2.zip
data/bulk-export-attachments/F033ZL9Q60K_Chevron 1.zip
data/bulk-export-attachments/F034C9LHS2D_Chevron 3.zip
data/bulk-export-attachments/F034PE7JA4Q_t-VwGqLwrOz--1-10.pdf
data/bulk-export-attachments/F0361S6K293_image.png
data/bulk-export-attachments/F0363N940P4_image.png
data/bulk-export-attachments/F036TEPR00G_image.png
data/bulk-export-attachments/F03A64DC934_tBzHuQGusUxW-2-300.png
data/bulk-export-attachments/F03A64DK0TU_tBzHuQGusUxW-4-292.png
data/bulk-export-attachments/F03A8EL4MHA_tBzHuQGusUxW-3-290.png
data/bulk-export-attachments/F03AVSHA8FJ_tBzHuQGusUxW-2-301.png
data/bulk-export-attachments/F03AVSHHADN_tBzHuQGusUxW-4-293.png
Validation complete
root@mattermost ~/mmctl-beta#
Thanks, this is helpful!
Do you still have the mattermost_import.jsonl file lying around somewhere? If so, could you please post the output of the following command:
head -3 /path/to/mattermost_import.jsonl
It should show references to the teamname. In my test export it looks like this:
root@mattermost ~# head -3 /opt/mattermost/data/mattermost_import.jsonl
{"type":"version","version":1}
{"type":"channel","channel":{"team":"slackimport","name":"general","display_name":"general","type":"O","header":"Company-wide announcements and work-based matters","purpose":"This channel is
for workspace-wide communication and announcements. All members are in this channel."}}
{"type":"channel","channel":{"team":"slackimport","name":"database","display_name":"database","type":"O","header":"","purpose":""}}
root@mattermost ~#
Looks good except for these two lines. They are too long. You could check the jsonl file for these lines and manually truncate them or split them into two lines. You‘d have to recreate the zip then and try again. All other things look good now!
OK I went in and fixed those two lines within the jsonl and I understand i need to recreate the zip and go from there. But what I’m wondering is do i need to go in and delete all of those folders that were created in opt/mattermost/data/ there seems to be about 190-200 new folders that are named with a date.
mmctl team list
mmctl channel list slackimport
mmctl user list
Can you see your team, your channels and your users when running these commands? Any superfluous information (like an additional team), or any other distorting entries?
OK, if you cannot see the channels then you’re probably not in the right team with your user account.
Please make sure your user is member of the slackimport team and if it’s not, you can either add it to this team using the system console or using mmctl:
mmctl team users add slackimport <yourusername>
You should then (after refreshing the app) see the teams switcher bar in the leftmost pane and can switch between the teams.
