Import From Slack: Error Uploading Data
I’m already a user of that channel and it is listed as the first one “anatwick” under the mmctl user list
i also tried logging out and logging back in - still only the two channels "Off-Topic and “Town Square”
You do not see all available channels here in the left pane. You do only see the channels you’ve entered once or searched for, so if you search for one of the channels using ctrl-k or click on the + icon at the top of then on Browse channels, can you see them then?
ohhhh strange… OK they do show up so i just need to manually search all 35 channels to get them to show up then i should be good
Yes, the left pane is not an index for all available channels, which might be confusing after the import. I think it would be good if the importer also joined you to the channels automatically and adds them to your LHS menu if you’re part of this channel on slack. @plusmid any idea if that would be possible?
To be honest, I thought that was already the case. Let me check.
The importer should join the users automatically. I’ll investigate further…
