I am using ReactQuill component in the root,
I cannot find a way to focus it until i expand the sidebar.
Is there any solution for that?
You may be able to, by adding a html
id="nameoflocation"
tag to the section of the html page you want to load, and then calling that ID with
https://[your URL path here]/#[nameoflocation] in your ReactQuill code.
Thank you,
Sorry, I did understand something,
How do I call https://[your URL path here]/#[nameoflocation]
Do I use fetch or what?
I haven’t used Quill personally for any projects, but I believe this might work, if you use this in your function:
MyEditor.modules = {
toolbar: {
container: "#[nameoflocation]",
'image-tooltip': true,
'link-tooltip': true,
handlers:{
[yourhandler]: [yourhandler]
And of course, the container properties within the toolbar module can be changed to fit your needs.
