When migrating a mattermost install to a new server, using GitLab omnibus, auth fails with ‘Bad response from token request’. I’ve attempted fresh installs multiple times purging everything and trying again multiple ways and the auth always fails.
Related GitLab bug where i’ve had no response yet.
Install gitlab-ce omnibus package on Ubuntu 18.04
Restore gitlab.rb.
Restore gitlab from backup
Install mattermost:
Start gitlab and reconfigure.gitlab-ctl start gitlab-ctl reconfigure gitlab-ctl restart -
Fix auth urls in /admin/applications
Here is my entire gitlab.rb (domain redacted), everything else is default:
external_url 'https://git.example.com'
gitlab_rails['gitlab_email_from'] = 'git@example.com'
gitlab_rails['gitlab_email_display_name'] = 'example.com git'
gitlab_rails['gitlab_username_changing_enabled'] = false
gitlab_rails['gitlab_default_projects_features_issues'] = false
gitlab_rails['gitlab_default_projects_features_wiki'] = false
gitlab_rails['backup_path'] = "/var/data/backup"
gitlab_rails['backup_keep_time'] = 691200
git_data_dirs({
"default" => {
"path" => "/var/data/git-data"
gitlab_rails['gitlab_shell_ssh_port'] = 27271
nginx['redirect_http_to_https'] = true
nginx['ssl_protocols'] = "TLSv1.2"
nginx['custom_nginx_config'] = "include /etc/gitlab/nginx/sites-enabled/*;"
mattermost_external_url 'https://chat.example.com'
mattermost['enable'] = true
mattermost['team_site_name'] = "example.com Chat"
mattermost['gitlab_enable'] = true
mattermost['gitlab_id'] = "ID"
mattermost['gitlab_secret'] = "SECRET"
mattermost['gitlab_auth_endpoint'] = "https://git.example.com/oauth/authorize"
mattermost['gitlab_token_endpoint'] = "https://git.example.com/oauth/token"
mattermost['gitlab_user_api_endpoint'] = "https://git.example.com/api/v4/user"
mattermost['file_directory'] = "/var/data/mattermost/data"
mattermost_nginx['redirect_http_to_https'] = true
mattermost_nginx['listen_addresses'] = ['*', '[::]']
letsencrypt['enable'] = true
What is the current bug behavior?
Attempt to login - ‘Error Bad response from token request’
I was successful enabling login by email and logging in. Mattermost is working, and the correct urls show up in the system console. I also checked the token in gitlab and the console and they are the same.
