Hi there!
I installed my mattermost server on digital ocean VPS running on Ubuntu 18.04.
As per the link https://docs.mattermost.com/install/install-ubuntu-1804.html# I did host my mattermost instance but am not able to access on default port 80. i.e. I am not able to access at http://mydomain.com but i am able to access at http://mydomain.com:8065
Can anyone please help me to understand though we configured NGINX as proxy for the mattermost server still why its not accessible at http://mydomain.com
My mydomain.net config file as follows:
upstream backend {
server localhost:8065;
keepalive 32;
server {
listen 80;
server_name myexample.com; (i used my domain here)
proxy_set_header Connection “upgrade”;
client_max_body_size 50M;
proxy_buffers 256 16k;
proxy_buffer_size 16k;
client_body_timeout 60;
send_timeout 300;
lingering_timeout 5;
proxy_connect_timeout 90;
proxy_send_timeout 300;
proxy_read_timeout 90s;
proxy_pass http://backend;
location / {
proxy_set_header Connection “”;
proxy_read_timeout 600s;
proxy_cache mattermost_cache;
proxy_cache_revalidate on;
proxy_cache_min_uses 2;
proxy_cache_lock on;
proxy_http_version 1.1;
Thanking you in advance.
