Mattermost not starting after migration
Dear support forum,
I succesfully migrated matermost from one mysql server to another server running postgres, but when I try to start, I get this error:
Error: failed to initialize platform: cannot create store: failed to apply database migrations: driver: postgres, message: failed to fetch current schema, command: current_schema, originalError: sql: Scan error on column index 0, name “current_schema”: converting NULL to string is unsupported, query:
How can I solve this problem?
Thanks in advance for your help.
The magic is in the Datasource in the param search_path. Watch too if you connection require SSL or not.
Try this:
“DataSource”: “postgres://your_user:your_password@your_host:5432/mattermost?sslmode=require\u0026search_path=mattermost,public”,
Thanks Felipe. I started from scratch the migration and worked.
This was the problem: Migration-assist tool hits a roadblock - migrating from mysql 8 to postgresql 15--Cannot connect to migrated postgresql db - #5 by agnivade
