Mattermost service not starting after upgrade
After upgrading Mattermost from v8.1.0 to v9.7.1 on Ubuntu server 22.04.4 LTS, I’m unable to start the Mattermost service again.
systemctl stop mattermost.service
sudo apt update -y
sudo apt upgrade
I’m using PostgreSQL. The database service is up and running normally.
with systemctl restart mattermost.service the server should be up and working again. I haven’t made any changes to the database or user/group rights on files/folders.
systemctl status mattermost.service outputs the following:
○ mattermost.service - Mattermost
     Loaded: loaded (/lib/systemd/system/mattermost.service; enabled; vendor preset: enabled)
     Active: inactive (dead) (Result: exit-code) since Wed 2024-04-24 19:32:21 UTC; 11h ago
    Process: 22814 ExecStart=/opt/mattermost/bin/mattermost (code=exited, status=1/FAILURE)
   Main PID: 22814 (code=exited, status=1/FAILURE)
        CPU: 6.276s
Apr 24 19:32:21 ov-9a01db systemd[1]: Stopped Mattermost.
Apr 24 19:32:21 ov-9a01db systemd[1]: mattermost.service: Consumed 6.276s CPU time.
when I systemctl restart mattermost.service it outputs the following:
Job for mattermost.service failed because the control process exited with error code.
journalctl -xeu mattermost.service outputs the following:
Apr 25 07:31:25 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:25.195 Z","level":"error","msg":"Failed to sync plugin from file store","caller":"app/plugin.go:344","plugin_id>
Apr 25 07:31:25 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:25.677 Z","level":"info","msg":"Installing extracted plugin","caller":"app/plugin_install.go:427","plugin_id":">
Apr 25 07:31:26 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:26.118 Z","level":"info","msg":"Installing extracted plugin","caller":"app/plugin_install.go:427","plugin_id":">
Apr 25 07:31:27 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.319 Z","level":"info","msg":"connectDatabase","caller":"app/plugin_api.go:1000","plugin_id":"focalboard","db>
Apr 25 07:31:27 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.334 Z","level":"info","msg":"Schema migration table is correct format","caller":"app/plugin_api.go:1000","pl>
Apr 25 07:31:27 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.334 Z","level":"info","msg":"{\"level\":\"info\",\"msg\":\"Pinging SQL\",\"fields\":{\"database\":\"master\">
Apr 25 07:31:27 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.384 Z","level":"info","msg":"Initialized notification backend","caller":"app/plugin_api.go:1000","plugin_id">
Apr 25 07:31:27 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.385 Z","level":"info","msg":"Initialized notification backend","caller":"app/plugin_api.go:1000","plugin_id">
Apr 25 07:31:27 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.399 Z","level":"info","msg":"Focalboard server","caller":"app/plugin_api.go:1000","plugin_id":"focalboard",">
Apr 25 07:31:27 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.399 Z","level":"info","msg":"Server.Start","caller":"app/plugin_api.go:1000","plugin_id":"focalboard"}
Apr 25 07:31:27 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.409 Z","level":"info","msg":"Boards product successfully started.","caller":"app/plugin_api.go:1000","plugin>
Apr 25 07:31:27 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.421 Z","level":"info","msg":"Processing prepackaged plugin","caller":"app/plugin.go:972","bundle_path":"/opt>
Apr 25 07:31:27 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.422 Z","level":"info","msg":"Processing prepackaged plugin","caller":"app/plugin.go:972","bundle_path":"/opt>
Apr 25 07:31:27 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.424 Z","level":"info","msg":"Processing prepackaged plugin","caller":"app/plugin.go:972","bundle_path":"/opt>
Apr 25 07:31:27 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.434 Z","level":"info","msg":"Processing prepackaged plugin","caller":"app/plugin.go:972","bundle_path":"/opt>
Apr 25 07:31:27 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.449 Z","level":"info","msg":"Processing prepackaged plugin","caller":"app/plugin.go:972","bundle_path":"/opt>
Apr 25 07:31:27 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.464 Z","level":"info","msg":"Processing prepackaged plugin","caller":"app/plugin.go:972","bundle_path":"/opt>
Apr 25 07:31:27 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.478 Z","level":"info","msg":"Processing prepackaged plugin","caller":"app/plugin.go:972","bundle_path":"/opt>
Apr 25 07:31:27 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.884 Z","level":"info","msg":"Not installing prepackaged plugin: not previously enabled","caller":"app/plugin>
Apr 25 07:31:27 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.931 Z","level":"info","msg":"Not installing prepackaged plugin: not previously enabled","caller":"app/plugin>
Apr 25 07:31:28 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.989 Z","level":"info","msg":"Installing extracted plugin","caller":"app/plugin_install.go:427","plugin_id":">
Apr 25 07:31:28 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:27.991 Z","level":"warn","msg":"Skipping local installation of plugin since not a newer version","caller":"app/>
Apr 25 07:31:28 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:28.013 Z","level":"warn","msg":"Error loading local plugin icon","caller":"app/plugin.go:1184","plugin_id":"mat>
Apr 25 07:31:28 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:28.013 Z","level":"info","msg":"Not installing prepackaged plugin: not previously enabled","caller":"app/plugin>
Apr 25 07:31:28 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:28.055 Z","level":"info","msg":"Not installing prepackaged plugin: not previously enabled","caller":"app/plugin>
Apr 25 07:31:28 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:28.064 Z","level":"info","msg":"Not installing prepackaged plugin: not previously enabled","caller":"app/plugin>
Apr 25 07:31:28 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:28.101 Z","level":"info","msg":"Not installing prepackaged plugin: not previously enabled","caller":"app/plugin>
Apr 25 07:31:28 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:28.140 Z","level":"info","msg":"Installing extracted plugin","caller":"app/plugin_install.go:427","plugin_id":">
Apr 25 07:31:28 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:28.141 Z","level":"warn","msg":"Skipping local installation of plugin since not a newer version","caller":"app/>
Apr 25 07:31:28 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:28.269 Z","level":"info","msg":"Installing extracted plugin","caller":"app/plugin_install.go:427","plugin_id":">
Apr 25 07:31:28 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:28.278 Z","level":"error","msg":"Failed to install prepackaged plugin","caller":"app/plugin.go:939","bundle_pat>
Apr 25 07:31:28 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:28.280 Z","level":"error","msg":"Unable to activate plugin","caller":"app/plugin.go:144","plugin_id":"com.matte>
Apr 25 07:31:28 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:28.356 Z","level":"info","msg":"Starting Server...","caller":"app/server.go:877"}
Apr 25 07:31:28 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:28.356 Z","level":"error","msg":"Error starting server, err:listen tcp :443: bind: permission denied: listen tc>
Apr 25 07:31:28 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:28.356 Z","level":"info","msg":"Stopping Server...","caller":"app/server.go:659"}
Apr 25 07:31:28 ov-9a01db mattermost[33595]: {"timestamp":"2024-04-25 07:31:28.522 Z","level":"info","msg":"Shutting down Email batching service...","caller":"email/service.go:85"}
I don’t really know what else I can try. Any help or suggestions most welcome !
Never mind ! I just found the solution ! :sweat_smile:
I had to activate again the CAP_NET_BIND_SERVICE capability as indicated on Configure TLS on Mattermost server - Mattermost documentation
I love this… so many times I’ve beaten my head against a problem, posted… and 30 seconds later was like OH YEAH, that’s what it is! :smiley: Thanks for posting your resolution.
