mattermost upgrade issue from 9.6.1-0
I’m using ubuntu 22.04.5 LTS (Jammy Jellyfish). I’ve installed mattermost-omnibus - 9.6.1-0 already. I’m trying to upgrade it to the latest version as per docs link: Install Mattermost Omnibus - Mattermost documentation
root@bot-mattermost:~#
root@bot-mattermost:~# sudo apt update && sudo apt upgrade
Hit:1 https://artifacts.elastic.co/packages/8.x/apt stable InRelease
Hit:2 http://in.archive.ubuntu.com/ubuntu jammy InRelease
Get:3 http://in.archive.ubuntu.com/ubuntu jammy-updates InRelease [128 kB]
Hit:4 http://nginx.org/packages/ubuntu jammy InRelease
Hit:5 https://deb.packages.mattermost.com stable InRelease
Get:6 http://in.archive.ubuntu.com/ubuntu jammy-backports InRelease [127 kB]
Hit:7 http://apt.postgresql.org/pub/repos/apt jammy-pgdg InRelease
Get:8 http://in.archive.ubuntu.com/ubuntu jammy-security InRelease [129 kB]
Get:9 http://in.archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages [2,112 kB]
Get:10 http://in.archive.ubuntu.com/ubuntu jammy-security/main amd64 Packages [1,893 kB]
Get:11 http://in.archive.ubuntu.com/ubuntu jammy-security/main Translation-en [305 kB]
Get:12 http://in.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages [911 kB]
Get:13 http://in.archive.ubuntu.com/ubuntu jammy-security/universe Translation-en [180 kB]
Fetched 5,785 kB in 5s (1,224 kB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
1 package can be upgraded. Run 'apt list --upgradable' to see it.
Calculating upgrade... Done
Get more security updates through Ubuntu Pro with 'esm-apps' enabled:
  zabbix-agent ansible
Learn more about Ubuntu Pro at https://ubuntu.com/pro
# Patches available for packages affected by CUPS Remote Code Execution issue
# tracked by CVE-2024-47076, CVE-2024-47175, CVE-2024-47176, and CVE-2024-47177
# For more see: https://ubuntu.com/blog/cups-remote-code-execution
The following packages have been kept back:
  distro-info-data
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
root@bot-mattermost:~# apt install mattermost-omnibus
mattermost-omnibus is already the newest version (9.6.1-0).
Please help us to upgrade this.
You probably need to re-do the step in Install Mattermost Omnibus - Mattermost documentation
