After restarting EC2 instance, Mattermost fails to start with the message
{“level”:“error”,“ts”:1539454659.400191,“caller”:“app/server.go:219”,“msg”:“Error starting server, err:open : no such file or directory”}
- Install 5.3.1 following the installation instructions, using Postgres on Amazon Linux
- Run it for two days without issue
- Shutdown EC2 instance at end of night
- Start EC2 instance the next morning. Mattermost hangs on start with an error about a missing file:
{“level”:“info”,“ts”:1539455002.8930788,“caller”:“utils/i18n.go:83”,“msg”:“Loaded system translations for ‘en’ from ‘/opt/mattermost/i18n/en.json’”}
{“level”:“info”,“ts”:1539455002.8931653,“caller”:“app/app.go:195”,“msg”:“Server is initializing…”}
{“level”:“info”,“ts”:1539455002.89509,“caller”:“sqlstore/supplier.go:200”,“msg”:“Pinging SQL master database”}
{“level”:“info”,“ts”:1539455002.9436934,“caller”:“commands/server.go:81”,“msg”:“Current version is 5.3.0 (5.3.1/Wed Sep 19 07:42:34 UTC 2018/fd21e53365d504155ab87f9bef60b1ab4faeb38d/c87ad1eeda18455c22a42ede7276194412e3a25f)”}
{“level”:“info”,“ts”:1539455002.9437466,“caller”:“commands/server.go:82”,“msg”:“Enterprise Enabled: true”}
{“level”:“info”,“ts”:1539455002.9437597,“caller”:“commands/server.go:83”,“msg”:“Current working directory is /opt/mattermost”}
{“level”:“info”,“ts”:1539455002.9437919,“caller”:“commands/server.go:84”,“msg”:“Loaded config file from /opt/mattermost/config/config.json”}
{“level”:“info”,“ts”:1539455002.9439156,“caller”:“utils/file_backend_local.go:32”,“msg”:“Able to write files to local storage.”}
{“level”:“info”,“ts”:1539455002.9449074,“caller”:“app/license.go:44”,“msg”:“License key from https://mattermost.com required to unlock enterprise features.”}
{“level”:“info”,“ts”:1539455002.9455242,“caller”:“app/plugin.go:100”,“msg”:“Starting up plugins”}
{“level”:“info”,“ts”:1539455003.4513152,“caller”:“app/server.go:88”,“msg”:“Starting Server…”}
{“level”:“info”,“ts”:1539455003.451441,“caller”:“app/server.go:148”,“msg”:“Server is listening on [::]:8065”}
{“level”:“error”,“ts”:1539455003.4516575,“caller”:“app/server.go:219”,“msg”:“Error starting server, err:open : no such file or directory”}
{“level”:“info”,“ts”:1539455003.4580114,“caller”:“app/web_hub.go:75”,“msg”:“Starting 4 websocket hubs”}
{“level”:“info”,“ts”:1539455003.4661472,“caller”:“sqlstore/post_store.go:1297”,“msg”:“Post.Message supports at most 16383 characters (65535 bytes)”}
{“level”:“info”,“ts”:1539455003.4952223,“caller”:“jobs/workers.go:62”,“msg”:“Starting workers”}
{“level”:“info”,“ts”:1539455003.4960074,“caller”:“jobs/schedulers.go:68”,“msg”:“Starting schedulers.”}
kill -9 the process
ps aux | grep mattermost
root 7654 0.0 0.0 119468 976 pts/0 S+ 14:40 0:00 grep --color=auto mattermost -
Enable debug logging in config/config.json
service mattermost start. Service hangs at scheduler with errors in logs (previous error as well as errors about plugin directories being in use)
The server should start without error
[root@ip-172-16-5-141 mattermost]# tail -n 200 logs/mattermost.log
{“level”:“info”,“ts”:1539456396.79089,“caller”:“utils/i18n.go:83”,“msg”:“Loaded system translations for ‘en’ from ‘/opt/mattermost/i18n/en.json’”}
{“level”:“info”,“ts”:1539456396.7910206,“caller”:“app/app.go:195”,“msg”:“Server is initializing…”}
{“level”:“debug”,“ts”:1539456396.7915618,“caller”:“utils/html.go:30”,“msg”:“Parsing server templates at /opt/mattermost/templates”}
{“level”:“info”,“ts”:1539456396.7929425,“caller”:“sqlstore/supplier.go:200”,“msg”:“Pinging SQL master database”}
{“level”:“debug”,“ts”:1539456396.8319116,“caller”:“sqlstore/preference_store.go:41”,“msg”:“Deleting any unused pre-release features”}
{“level”:“debug”,“ts”:1539456396.834403,“caller”:“jobs/schedulers.go:29”,“msg”:“Initialising schedulers.”}
{“level”:“info”,“ts”:1539456396.83456,“caller”:“commands/server.go:81”,“msg”:“Current version is 5.3.0 (5.3.1/Wed Sep 19 07:42:34 UTC 2018/fd21e53365d504155ab87f9bef60b1ab4faeb38d/c87ad1eeda18455c22a42ede7276194412e3a25f)”}
{“level”:“info”,“ts”:1539456396.8345916,“caller”:“commands/server.go:82”,“msg”:“Enterprise Enabled: true”}
{“level”:“info”,“ts”:1539456396.8346014,“caller”:“commands/server.go:83”,“msg”:“Current working directory is /opt/mattermost”}
{“level”:“info”,“ts”:1539456396.8346443,“caller”:“commands/server.go:84”,“msg”:“Loaded config file from /opt/mattermost/config/config.json”}
{“level”:“info”,“ts”:1539456396.8347473,“caller”:“utils/file_backend_local.go:32”,“msg”:“Able to write files to local storage.”}
{“level”:“debug”,“ts”:1539456396.834961,“caller”:“jobs/schedulers.go:29”,“msg”:“Initialising schedulers.”}
{“level”:“debug”,“ts”:1539456396.835594,“caller”:“utils/license.go:83”,“msg”:“We could not find the license key in the database or on disk at /opt/mattermost/config/mattermost.mattermost-license”}
{“level”:“info”,“ts”:1539456396.8360565,“caller”:“app/license.go:44”,“msg”:“License key from https://mattermost.com required to unlock enterprise features.”}
{“level”:“info”,“ts”:1539456396.8367288,“caller”:“app/plugin.go:100”,“msg”:“Starting up plugins”}
{“level”:“error”,“ts”:1539456397.0310977,“caller”:“app/plugin.go:129”,“msg”:“Failed to unpack prepackaged plugin”,“error”:“installPlugin: Unable to move plugin from temporary directory to final destination. Another plugin may be using the same directory name., destination already exists”,“path”:"/opt/mattermost/prepackaged_plugins/mattermost-jira-plugin-linux-amd64.tar.gz"}
{“level”:“error”,“ts”:1539456397.2281704,“caller”:“app/plugin.go:129”,“msg”:“Failed to unpack prepackaged plugin”,“error”:“installPlugin: Unable to move plugin from temporary directory to final destination. Another plugin may be using the same directory name., destination already exists”,“path”:"/opt/mattermost/prepackaged_plugins/mattermost-zoom-plugin-linux-amd64.tar.gz"}
{“level”:“error”,“ts”:1539456397.228276,“caller”:“app/plugin.go:55”,“msg”:“Plugin manifest could not be loaded”,“plugin_path”:“plugins/jira”,“error”:“open plugins/jira/plugin.yml: permission denied”}
{“level”:“error”,“ts”:1539456397.2283008,“caller”:“app/plugin.go:55”,“msg”:“Plugin manifest could not be loaded”,“plugin_path”:“plugins/zoom”,“error”:“open plugins/zoom/plugin.yml: permission denied”}
{“level”:“info”,“ts”:1539456397.2285974,“caller”:“app/server.go:88”,“msg”:“Starting Server…”}
{“level”:“info”,“ts”:1539456397.228812,“caller”:“app/server.go:148”,“msg”:“Server is listening on [::]:8065”}
{“level”:“error”,“ts”:1539456397.229114,“caller”:“app/server.go:219”,“msg”:“Error starting server, err:open : no such file or directory”}
{“level”:“debug”,“ts”:1539456397.235222,“caller”:“api4/plugin.go:20”,“msg”:“EXPERIMENTAL: Initializing plugin api”}
{“level”:“info”,“ts”:1539456397.2356615,“caller”:“app/web_hub.go:75”,“msg”:“Starting 4 websocket hubs”}
{“level”:“debug”,“ts”:1539456397.2357197,“caller”:“web/web.go:27”,“msg”:“Initializing web routes”}
{“level”:“debug”,“ts”:1539456397.2358732,“caller”:“utils/subpath.go:59”,“msg”:“No rewrite required for static assets”,“path”:"/static/"}
{“level”:“debug”,“ts”:1539456397.235861,“caller”:“app/web_hub.go:400”,“msg”:“Hub for index 1 is starting with goroutine 2468”}
{“level”:“debug”,“ts”:1539456397.2359037,“caller”:“web/static.go:26”,“msg”:“Using client directory at /opt/mattermost/client”}
{“level”:“debug”,“ts”:1539456397.2359598,“caller”:“app/web_hub.go:400”,“msg”:“Hub for index 0 is starting with goroutine 2467”}
{“level”:“debug”,“ts”:1539456397.236125,“caller”:“app/web_hub.go:400”,“msg”:“Hub for index 2 is starting with goroutine 2469”}
{“level”:“debug”,“ts”:1539456397.2362182,“caller”:“app/web_hub.go:400”,“msg”:“Hub for index 3 is starting with goroutine 2470”}
{“level”:“info”,“ts”:1539456397.2430675,“caller”:“sqlstore/post_store.go:1297”,“msg”:“Post.Message supports at most 16383 characters (65535 bytes)”}
{“level”:“error”,“ts”:1539456397.2434707,“caller”:“app/plugin.go:55”,“msg”:“Plugin manifest could not be loaded”,“plugin_path”:“plugins/jira”,“error”:“open plugins/jira/plugin.yml: permission denied”}
{“level”:“error”,“ts”:1539456397.2435052,“caller”:“app/plugin.go:55”,“msg”:“Plugin manifest could not be loaded”,“plugin_path”:“plugins/zoom”,“error”:“open plugins/zoom/plugin.yml: permission denied”}
{“level”:“error”,“ts”:1539456397.2435777,“caller”:“app/plugin.go:55”,“msg”:“Plugin manifest could not be loaded”,“plugin_path”:“plugins/jira”,“error”:“open plugins/jira/plugin.yml: permission denied”}
{“level”:“error”,“ts”:1539456397.2435951,“caller”:“app/plugin.go:55”,“msg”:“Plugin manifest could not be loaded”,“plugin_path”:“plugins/zoom”,“error”:“open plugins/zoom/plugin.yml: permission denied”}
{“level”:“error”,“ts”:1539456397.2675183,“caller”:“app/plugin.go:55”,“msg”:“Plugin manifest could not be loaded”,“plugin_path”:“plugins/jira”,“error”:“open plugins/jira/plugin.yml: permission denied”}
{“level”:“error”,“ts”:1539456397.2675717,“caller”:“app/plugin.go:55”,“msg”:“Plugin manifest could not be loaded”,“plugin_path”:“plugins/zoom”,“error”:“open plugins/zoom/plugin.yml: permission denied”}
{“level”:“error”,“ts”:1539456397.2686849,“caller”:“app/plugin.go:55”,“msg”:“Plugin manifest could not be loaded”,“plugin_path”:“plugins/jira”,“error”:“open plugins/jira/plugin.yml: permission denied”}
{“level”:“error”,“ts”:1539456397.2687209,“caller”:“app/plugin.go:55”,“msg”:“Plugin manifest could not be loaded”,“plugin_path”:“plugins/zoom”,“error”:“open plugins/zoom/plugin.yml: permission denied”}
{“level”:“info”,“ts”:1539456397.2705193,“caller”:“jobs/workers.go:62”,“msg”:“Starting workers”}
{“level”:“info”,“ts”:1539456397.270818,“caller”:“commands/server.go:265”,“msg”:“Sending systemd READY notification.”}
{“level”:“debug”,“ts”:1539456397.272278,“caller”:“sqlstore/session_store.go:227”,“msg”:“Cleaning up session store.”}
{“level”:“debug”,“ts”:1539456397.2724757,“caller”:“sqlstore/tokens_store.go:72”,“msg”:“Cleaning up token store.”}
{“level”:“debug”,“ts”:1539456397.2726328,“caller”:“sqlstore/command_webhook_store.go:88”,“msg”:“Cleaning up command webhook store.”}
{“level”:“debug”,“ts”:1539456397.2728262,“caller”:“migrations/worker.go:44”,“msg”:“Worker started”,“worker”:“Migrations”}
{“level”:“debug”,“ts”:1539456397.2728393,“caller”:“jobs/jobs_watcher.go:39”,“msg”:“Watcher Started”}
{“level”:“info”,“ts”:1539456397.27287,“caller”:“jobs/schedulers.go:68”,“msg”:“Starting schedulers.”}
{“level”:“debug”,“ts”:1539456397.279431,“caller”:“jobs/schedulers.go:163”,“msg”:“Next run time for scheduler MigrationsScheduler: 2018-10-13 14:47:37.279419437 -0400 EDT m=+60.639404180”}
