I hit a problem with my mattermost upgrade that is not listed in the migration-assist errors. I had to build my own pgloader due to mysql server having sha2 authentication but after I figured that out and the heap error issues it finally finished the migration. Though there are several warnings about columns. Once I hit Step 5 - Restore full-text indexes & create all indexes I get the following error output which doesnt make sense
@SERVER/mattermost"
2025-11-15 21:07:14 could not find the default schema “public” in search_path, consider setting it from the postgresql console
2025-11-15 21:07:14 search_path is set to “public” for the currrent session
2025-11-15 21:07:14 running migrations..
2025-11-15 21:07:14 applying create_idx_fileinfo_content_txt.sql
2025-11-15 21:07:16 Index creation failed due to content being too long for tsvector.
This is expected if you have a large amount of data.
Please run the migration manually and refer to the documentation page below:
migration log warnings
2025-11-15T21:03:58.025011Z WARNING Source column “mattermost”.“ChannelBookmarks”.“displayname” is casted to type “varchar” which is not the same as “text”, >
2025-11-15T21:03:58.025011Z WARNING Source column “mattermost”.“ChannelBookmarks”.“sortorder” is casted to type “bigint” which is not the same as “integer”, >
2025-11-15T21:03:58.025011Z WARNING Source column “mattermost”.“ChannelBookmarks”.“linkurl” is casted to type “varchar” which is not the same as “text”, the >
2025-11-15T21:03:58.025011Z WARNING Source column “mattermost”.“ChannelBookmarks”.“imageurl” is casted to type “varchar” which is not the same as “text”, the>
2025-11-15T21:03:58.025011Z WARNING Source column “mattermost”.“ChannelBookmarks”.“type” is casted to type “channel_bookmark_type” which is not the same as ">
2025-11-15T21:03:58.025011Z WARNING Source column “mattermost”.“ChannelMembers”.“schemeuser” is casted to type “smallint” which is not the same as “boolean”,>
2025-11-15T21:03:58.025011Z WARNING Source column “mattermost”.“ChannelMembers”.“schemeadmin” is casted to type “smallint” which is not the same as “boolean”>
2025-11-15T21:03:58.025011Z WARNING Source column “mattermost”.“ChannelMembers”.“schemeguest” is casted to type “smallint” which is not the same as “boolean”>
2025-11-15T21:03:58.025011Z WARNING Source column “mattermost”.“Channels”.“type” is casted to type “channel_type” which is not the same as "mattermost.channe>
2025-11-15T21:03:58.025011Z WARNING Source column “mattermost”.“OutgoingOAuthConnections”.“oauthtokenurl” is casted to type “varchar” which is not the same a>
2025-11-15T21:03:58.025011Z WARNING Source column “mattermost”.“OutgoingOAuthConnections”.“granttype” is casted to type “varchar” which is not the same as "m>
2025-11-15T21:03:58.025011Z WARNING Source column “mattermost”.“Preferences”.“value” is casted to type “varchar” which is not the same as “text”, the type of>
2025-11-15T21:03:58.026011Z WARNING Source column “mattermost”.“RetentionIdsForDeletion”.“ids” is casted to type “jsonb” which is not the same as "character >
2025-11-15T21:03:58.026011Z WARNING Source column “mattermost”.“ScheduledPosts”.“priority” is casted to type “varchar” which is not the same as “text”, the t>
2025-11-15T21:03:58.026011Z WARNING Source column “mattermost”.“TeamMembers”.“schemeuser” is casted to type “smallint” which is not the same as “boolean”, th>
2025-11-15T21:03:58.026011Z WARNING Source column “mattermost”.“TeamMembers”.“schemeadmin” is casted to type “smallint” which is not the same as “boolean”, t>
2025-11-15T21:03:58.026011Z WARNING Source column “mattermost”.“TeamMembers”.“schemeguest” is casted to type “smallint” which is not the same as “boolean”, t>
2025-11-15T21:03:58.026011Z WARNING Source column “mattermost”.“Teams”.“type” is casted to type “team_type” which is not the same as “mattermost.team_type”, >
2025-11-15T21:03:58.026011Z WARNING Source column “mattermost”.“UploadSessions”.“type” is casted to type “upload_session_type” which is not the same as "matt>
2025-11-15T21:03:58.034012Z WARNING PostgreSQL warning: constraint “fk_retentionpolicieschannels_retentionpolicies” of relation “retentionpolicieschannels” d>
2025-11-15T21:03:58.034012Z WARNING PostgreSQL warning: constraint “fk_retentionpoliciesteams_retentionpolicies” of relation “retentionpoliciesteams” does no>
2025-11-15T21:04:34.559417Z LOG report summary reset
migration.load:
WITH data only,
prefetch rows = 500,
workers = 8, concurrency = 1,
multiple readers per thread, rows per range = 10000,
prefetch rows = 10000, batch rows = 2500,
create no tables, create no indexes,
preserve index names
SET PostgreSQL PARAMETERS
maintenance_work_mem to ‘128MB’,
work_mem to ‘12MB’
SET MySQL PARAMETERS
net_read_timeout = ‘120’,
net_write_timeout = ‘120’
CAST column Channels.Type to “channel_type” drop typemod,
column Teams.Type to “team_type” drop typemod,
column UploadSessions.Type to “upload_session_type” drop typemod,
column ChannelBookmarks.Type to “channel_bookmark_type” drop typemod,
column Drafts.Priority to text,
type int when (= precision 11) to integer drop typemod,
type bigint when (= precision 20) to bigint drop typemod,
type text to varchar drop typemod using remove-null-characters,
type tinyint when (<= precision 4) to boolean using tinyint-to-boolean,
type json to jsonb drop typemod using remove-null-characters
EXCLUDING TABLE NAMES MATCHING ~<IR_>, ~, ~, ‘schema_migrations’, ‘db_migrations’, ‘db_lock’,
‘configurations’, ‘configurationfiles’, ‘db_config_migrations’
BEFORE LOAD DO
$$ ALTER SCHEMA public RENAME TO mattermost; $$,
$$ TRUNCATE TABLE mattermost.systems; $$,
$$ DROP INDEX IF EXISTS mattermost.idx_posts_message_txt; $$,
$$ DROP INDEX IF EXISTS mattermost.idx_fileinfo_content_txt; $$
AFTER LOAD DO
$$ UPDATE mattermost.db_migrations set name=‘add_createat_to_teamembers’ where version=92; $$,
$$ ALTER SCHEMA mattermost RENAME TO public; $$,
$$ SELECT pg_catalog.set_config(‘search_path’, ‘“$user”, “$user”, public’, false); $$,
$$ ALTER USER mmuser SET SEARCH_PATH TO ‘“$user”, public’; $$;
I also encountered an issue with database ownership that was not covered in the target database setup section
I did not apply the following step due to my postgres being v14 unless im mistaken.
If using PostgreSQL v15.x or later, additional grants are required:
ALTER DATABASE mattermost OWNER TO mmuser; ALTER SCHEMA public OWNER TO mmuser; GRANT USAGE, CREATE ON SCHEMA public TO mmuser;
which is weird since even if I would apply this step it would still error out.
I did have to apply the mmuser to own the mattermost server rather than the postgres user which allowed the migration to continue.
Any help would be great.
