For the preview of videos (all types), but not audio
Any type of videos file (mov, mp4), and any size (tested with 50MB and 1MB)
Latest version used
Certainly a problem with the Nginx configuration, because it works locally (bypassing nginx)
Nginx configuration
upstream backend {
server 10.10.10.2:8065;
keepalive 32;
server {
listen 80 default_server;
server_name mattermost.example.com;
server {
listen 443 ssl http2;
http2_push_preload on; # Enable HTTP/2 Server Push
ssl on;
ssl_certificate /etc/letsencrypt/live/mattermost.example.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/mattermost.example.com/privkey.pem;
ssl_session_timeout 1d;
# Enable TLS versions (TLSv1.3 is required upcoming HTTP/3 QUIC).
# Enable TLSv1.3's 0-RTT. Use $ssl_early_data when reverse proxying to
# prevent replay attacks.
# @see: https://nginx.org/en/docs/http/ngx_http_ssl_module.html#ssl_early_data
ssl_early_data on;
ssl_ciphers '...'
ssl_prefer_server_ciphers on;
ssl_session_cache shared:SSL:500m;
# HSTS (ngx_http_headers_module is required) (15768000 seconds = 6 months)
# OCSP Stapling ---
ssl_stapling on;
ssl_stapling_verify on;
add_header X-Early-Data $tls1_3_early_data;
client_max_body_size 500M;
proxy_buffers 256 16k;
proxy_buffer_size 16k;
client_body_timeout 60;
send_timeout 300;
lingering_timeout 5;
proxy_connect_timeout 90;
proxy_send_timeout 300;
proxy_read_timeout 90s;
proxy_http_version 1.1;
proxy_pass http://localhost:8065;
location / {
proxy_read_timeout 600s;
proxy_cache mattermost_cache;
proxy_cache_revalidate on;
proxy_cache_min_uses 2;
proxy_cache_lock on;
# This block is useful for debugging TLS v1.3. Please feel free to remove this
# and use the `$ssl_early_data` variable exposed by NGINX directly should you
# wish to do so.
map $ssl_early_data $tls1_3_early_data {
"~." $ssl_early_data;
default "";
Any clues ?
