Oauth not valid behind reverse proxy
Hello everyone,
I am using gitlab and mattermost behind reverse proxy on same domain and same server (as I use omnibus installation).
When I try to make the link between mattermost and gitlab by creating a team on the mattermost startup screen, I am redirected to Gitlab to validate the application but I have this error : The redirect URI included is not valid.
When I check the url, I can see that there is http instead of https : https://git.domain.com/oauth/authorize?response_type=code&client_id=xxxxxx&redirect_uri=http%3A%2F%2Fmat.domain.com%2Fsignup%2Fgitlab%2Fcomplete&state=yyyyyyyyy
How can I change http to https in the redirect_uri parameter ? When I change it manually, Gitlab seems to detect mattermost.
Here is my gitlab.rb : external_url ‘https://git.domain.com
nginx[‘listen_port’] = 80
nginx[‘listen_https’] = false
mattermost_external_url ‘https://mat.domain.com
mattermost_nginx[‘listen_port’] = 80
mattermost_nginx[‘listen_https’] = false
Thank you in advance for your help
Having the same issue here, do you have any update @kyryus?
Salut/Hello @pierreozoux,
I manage to make it work by adding :
nginx['proxy_set_headers'] = {
  "Host" => "$http_host",
  "X-Real-IP" => "$remote_addr",
  "X-Forwarded-For" => "$proxy_add_x_forwarded_for",
  "X-Forwarded-Proto" => "https",
  "X-Forwarded-Ssl" => "on"
and also this I think :
mattermost_nginx[‘proxy_set_headers’] = {
“Host” => “$http_host”,
“X-Real-IP” => “$remote_addr”,
“X-Forwarded-For” => “$proxy_add_x_forwarded_for”,
“X-Forwarded-Proto” => “https”,
“X-Forwarded-Ssl” => “on”
In my gitlab.rb
I am not really sure because I got it work but I did not liked Mattermost, I move to RocketChat.
I thought that Mattermost would be integrated inside GITLAB but it is not like this.
Hope that it helped you,
Bye
Thanks a lot @kyryus I managed thanks to your help!
Here is my setup for people interested: https://github.com/pierreozoux/mattermost-docker
