Your PostgreSQL Queries seem to be slow and the error message you posted indicates that this specific query took longer than the time allowed for queries to run and has been cancled because of that.
When was the last time you vacuumed your PostgreSQL database?
How long does running this specific query take on your installation? How many posts are there in your posts table?
SELECT p.*, (SELECT COUNT(*) FROM Posts WHERE Posts.RootId = (CASE WHEN p.RootId = '' THEN p.Id ELSE p.RootId END) AND Posts.DeleteAt = 0) AS ReplyCount FROM Posts p WHERE (CreateAt < (SELECT CreateAt FROM Posts WHERE Id = 'something') AND p.ChannelId = 'something' AND p.DeleteAt = 0) ORDER BY p.ChannelId, p.DeleteAt, p.CreateAt DESC LIMIT 30 OFFSET 0;
select count(*) from posts;
The query analyzer output might also be interesting for this specific query, you could run it with explain analyze verbose so that it generates an output like this:
mattermost=# explain analyze verbose SELECT p.*, (SELECT COUNT(*) FROM Posts WHERE Posts.RootId = (CASE WHEN p.RootId = '' THEN p.Id ELSE p.RootId END) AND Posts.DeleteAt = 0) AS ReplyCount FROM Posts p WHERE (CreateAt < (SELECT CreateAt FROM Posts WHERE Id = 'something') AND p.ChannelId = 'something' AND p.DeleteAt = 0) ORDER BY p.ChannelId, p.DeleteAt, p.CreateAt DESC LIMIT 30 OFFSET 0;
QUERY PLAN
Limit (cost=8.58..25.24 rows=1 width=374) (actual time=0.024..0.025 rows=0 loops=1)
Output: p.id, p.createat, p.updateat, p.deleteat, p.userid, p.channelid, p.rootid, p.originalid, p.message, p.type, p.props, p.hashtags, p.filenames, p.fileids, p.hasreactions, p.editat, p.ispinned, p.remoteid, ((SubPlan 1))
InitPlan 2 (returns $2)
-> Index Scan using posts_pkey on public.posts posts_1 (cost=0.28..8.30 rows=1 width=8) (actual time=0.019..0.020 rows=0 loops=1)
Output: posts_1.createat
Index Cond: ((posts_1.id)::text = 'something'::text)
-> Index Scan Backward using idx_posts_channel_id_delete_at_create_at on public.posts p (cost=0.28..16.94 rows=1 width=374) (actual time=0.023..0.023 rows=0 loops=1)
Output: p.id, p.createat, p.updateat, p.deleteat, p.userid, p.channelid, p.rootid, p.originalid, p.message, p.type, p.props, p.hashtags, p.filenames, p.fileids, p.hasreactions, p.editat, p.ispinned, p.remoteid, (SubPlan 1)
Index Cond: (((p.channelid)::text = 'something'::text) AND (p.deleteat = 0) AND (p.createat < $2))
SubPlan 1
-> Aggregate (cost=8.62..8.63 rows=1 width=8) (never executed)
Output: count(*)
-> Index Only Scan using idx_posts_root_id_delete_at on public.posts (cost=0.29..8.59 rows=15 width=0) (never executed)
Output: posts.rootid, posts.deleteat
Index Cond: ((posts.rootid = (CASE WHEN ((p.rootid)::text = ''::text) THEN p.id ELSE p.rootid END)::text) AND (posts.deleteat = 0))
Heap Fetches: 0
Planning Time: 0.332 ms
Execution Time: 0.066 ms
(18 rows)
