PostgreSQL error when migrating from 5.39.0 to 6.0.0
errors during the database schema migration of the PostgreSQL database when starting up the 6.0.0 version with a PostgreSQL 13.4 database.
mattermost_db_1  | 2021-10-13 13:09:20.210 UTC [332] ERROR:  default for column "timezone" cannot be cast automatically to type jsonb
mattermost_db_1  | 2021-10-13 13:09:20.210 UTC [332] STATEMENT:  ALTER TABLE users ALTER COLUMN timezone TYPE jsonb USING timezone::jsonb;
using the PostgreSQL queries from
This step fails:
migration should work without errors
I went now back to 5.39.0
@streamer45 @agnivade ^
Confirmed. I experienced the same errors when migration from 5.38 to 6.0.
Software version:
  • psql (PostgreSQL) 11.13 (Debian 11.13-0+deb10u1).
I recovered database from the backup and went back to 5.38, awaiting for the fix.
I was able to get this working, but I would have the MM team verify this is a fix.
On the Mattermost database (PostgreSQL)
ALTER TABLE users ALTER COLUMN timezone DROP DEFAULT;
ALTER TABLE users ALTER COLUMN timezone SET DEFAULT '{"automaticTimezone":"","manualTimezone":"","useAutomaticTimezone":"true"}';
The last one may not be correct, but after doing this I was able to get MM 6.0.0 running.
Thanks all. Yes, we are releasing a dot release along with a couple other fixes.
In the mean while, as a workaround, you can run:
and re-run Mattermost again.
