Prometheus exporter plugin?
I am using free edition, and looking for monitoring usage, such as posts count, last connection, last message etc…
With Prometheus or Grafana Alloy.
Is it a plugin to do that?
https://docs.mattermost.com/scale/deploy-prometheus-grafana-for-performance-monitoring.html
Only for the Enterprise tier…
thanks you John, that’s why I am looking for a plugin ^^
I am going to write a small exporter, that use the API, but i am wondering if something exist already.
You might see if CERN has a public repo. They might have something.
There is a plugin GitHub - mattermost/mattermost-plugin-metrics: Openmetrics scraper for Mattermost server. But the metrics endpoint isn’t exposed unless you have an enterprise license. So it’s not possible to use the plugin without a license.
I have done mine!
My 1st plugin, woa guys your plugin project template is so nice to use ^^ good job. I am not a golang expert, but in 2 days I have written this:
And it works fine!
