Rebranding "Mattermost" to "<companyname>"
Hi, I have succeeded in getting a self-hosted version of mattermost team edition running on AWS and was wondering if there is a quick way to change mentions of “Mattermost” to “MyComanyName” other than searching and replacing the files manually?
The only references to re-branding I have found so far when searching relate to either changes to the theme UI or custom features associated with the enterprise edition.
Many thanks
Hello there.
The current option for rebranding offered by Mattermost is explained in the official documentation here in general. For more details, check on the Customization section which involves changing values in the config.json file.
Hope that helps.
