What’s changing?
Beginning in Mattermost v11 (estimated in October 2025), the web app will no longer expose the Styled Components dependency for use by web app plugins.
Why are we making this change?
As part of ongoing maintenance of Mattermost, we occasionally reevaluate the dependencies of the web app to reduce the maintenance burden on the app and to improve performance by reducing code size.
Who will be afffected?
The only plugin that we expect to be affected by these changes is Playbooks, and it’ll only affect versions of Playbooks older than v2.3.0.
We don’t expect other plugins to be affected as this dependency was not made available as part of the Mattermost plugin starter template or demo plugin.
What do you need to do as a server operator?
If you use Playbooks, you will need to upgrade to v2.3.0 or newer.
What do you need to do as a plugin maintainer?
While we don’t expect this to be the case, if you maintain a plugin which relies on the web app to provide the Styled Components library, you will need to update your plugin to include that in the bundle. That can be done by removing the entry for styled-components from the externals section of the Webpack config.
