Resetting Gitlab Omnibus Mattermost installation
Hi Team,
I am trying to completely reset the Mattermost part of my installation.
So basically something like gitlab-ctl cleanse but only for mattermost.
Is this easily possible?
:+1:
This would hugely helpful. Our early testing has gone very well, but we want to wipe the slate clean before we start using it more broadly.
Hi @micheee, hi @Zuhkov,
Requests for additions to gitlab-ctl would need to go into GitLab’s system, not sure the perfect place but maybe start with https://gitlab.com/gitlab-org/omnibus-gitlab/issues?
Mattermost is design as an archive, so there’s not a straight forward way to reset the database right now. We’ve created a ticket to track the addition of a “Reset Server” command to ./platform that could do something similar to what’s being requested of gitlab-ctl: https://mattermost.atlassian.net/browse/PLT-975
Thanks, to both of you!
I see that adding such a feature to platform makes much more sense. I will read through the story and maybe add a thought if necessary :thought_balloon:.
Thanks for a great tool that’s fun to use.
Here’s what worked for me (use at your own risk):
  1. Login to the database
     sudo -u gitlab-psql /opt/gitlab/embedded/bin/psql -h /var/opt/gitlab/postgresql -d gitlabhq_production
  2. Drop mattermost DB
     drop database mattermost_production;
  3. Exit (\q) and run
     gitlab-ctl reconfigure
The last step will recreate the database
I think the way you’ve outlined it in your ticket will cover it, generally.
Couple questions/observations:
  • In the omnibus builds ./platform becomes ./mattermost. Having that info (plus the default path) in the docs would make things a lot easier when dealing with the CLI.
  • Who handles the integration of Mattermost into GitLab Omnibus? It seems like it would relatively simple to put together some kind of analogue for @3rdcycle’s solution, but would the Mattermost team handle that or would the GitLab guys do that?
Great answer. Helped me a lot!
I tried to drop the database as described by @3rdcycle, but the command gitlab-psql cannot be found.
I used omnibus installation for Gitlab 8.0 and upgraded recently to Gitlab 8.4 (Mattermost 0.7-Beta to 1.4.0 respectively).
How can I launch the gitlab-psql command?
Did you forget the -u? gitlab-psql is the user under which the command (psql) is executed, not the command itself.
You’re right :blush:
sudo isn’t installed, therefore I had missed that. Used instead su gitlab-psql. Thanks!
That ticket is now closed but only the first two commands have been added to ./platform, as far as I can see. Is a full reset command off the table?
I’m not understanding how this works. I can’t seem to figure out how to reset Mattermost on my GitLab installation. Can someone clarify this?
I dropped the mattermost database as described by @3rdcycle. Now Mattermost is showing the following error
GitLab Mattermost needs your help:
We could not get all teams
UPDATE
I disabled mattermost integration. Executed gitlab-ctl reconfigure. Re-enabled mattermost and again executed gitlab-ctl reconfigure. This time it worked.
