Hello, is there a good way to query a channel for all posts that have been created using a webhook?
I can see that a post - created by a webhook - has the following information set:
"zfs19y7qttgqjjbcjyz6atu3pr": {
"id": "zfs19y7qttgqjjbcjyz6atu3pr",
"create_at": 1646053476161,
"update_at": 1646053476161,
"props": {
"from_webhook": "true",
"webhook_display_name": "Some fancy Webhook name"
Is there a better way as to do a brute force “get all posts and check result for props set” using GetPostsFor Channel (Mattermost API Reference) ?
The reason I asked is because people have created Incoming Webhooks but not restricted the channels to which the webhook should post; so I now need to find out on which channels the webhook might have been posted.
Thanks in advance,
Rainer
