Secure SMTP on port 587 not working
Unable to enable secure SMTP connection.
We are using Mattermost 5.18, until recently we were using non-secure SMTP on port 25, however starting in 2020 IT has disabled that option and we are only allowed to use SMTP with TLS 1.2 on port 587.
I expect the SMTP “Test Connection” to be Successful.
Instead what I see is the following error message:
Connection unsuccessful: Connection unsuccessful: SendMail: Failed to open TLS connection, tls: first record does not look like a TLS handshake
Here is what is in our config.json:
 "EmailSettings": {
        "EnableSignUpWithEmail": false,
        "EnableSignInWithEmail": false,
        "SendEmailNotifications": true,
        "FeedbackName": "TechTalk",
        "FeedbackEmail": "techtalk@example.com",
        "ReplyToAddress": "test@example.com",
        "FeedbackOrganization": "",
        "EnableSMTPAuth": true,
        "SMTPUsername": "correct_username",
        "SMTPPassword": "correct_password",
        "SMTPServer": "correct_server_address",
        "SMTPPort": "587",
        "ConnectionSecurity": "TLS",
        "SendPushNotifications": false,
        "PushNotificationServer": "",
        "PushNotificationContents": "generic_no_channel",
        "EnableEmailBatching": false,
        "EmailBatchingInterval": 30,
        "SkipServerCertificateVerification": true,
faced the same issue but 465 and TLS works, so it is save to use 465.
Actually using port 587 is our only option. I I did manage to get it working.
There were a couple of configuration issues on our end, I had to change from TLS to STARTTLS. I figured that out by using telnet to connect to the SMTP server and it mentioned STARTTLS, so I changed the setting in the Mattermost UI.
What ended up being the second problem was the username. Back when we were using non-secure SMTP server on port 25, the login included the domain (e.g. domain/username) for some reason I discovered that with the secure server on port 587, I had to remove the domain from the username to get the authentication to work.
did you do this in the mattermost container or in the host?
Actually our instance is not currently running in a container, so to answer your question, I used telnet on the host to debug, and then once I figured it out, I changed the SMTP settings via the Mattermost UI.
