Hi All,
I have this issue when trying to test my email setup. I am running v 1.0 in Docker. And followed this guide for Ubuntu 14.04 https://github.com/mattermost/platform/blob/master/doc/install/Docker-Single-Container.md#ubuntu.
TLS Errors:
[2015/10/07 11:24:27 UTC] [DEBG] /api/v1/admin/config
[2015/10/07 11:24:31 UTC] [DEBG] /api/v1/admin/test_email
[2015/10/07 11:24:31 UTC] [EROR] /api/v1/admin/test_email:SendMail code=500 rid=rsqndjxn3f8r7puttryj6epm9y uid=5jtgo5cftbbc7du17n63nznxac ip=192.168.3.68 Failed to open TLS connection [details: tls: first record does not look like a TLS handshake]
[2015/10/07 11:24:32 UTC] [DEBG] /api/v1/admin/test_email
[2015/10/07 11:24:33 UTC] [EROR] /api/v1/admin/test_email:SendMail code=500 rid=ybbi4ppexpggdeupkfhcjbkr1r uid=5jtgo5cftbbc7du17n63nznxac ip=192.168.3.68 Failed to open TLS connection [details: tls: first record does not look like a TLS handshake]
[2015/10/07 11:24:33 UTC] [DEBG] /api/v1/admin/test_email
[2015/10/07 11:24:33 UTC] [EROR] /api/v1/admin/test_email:SendMail code=500 rid=ok85dy6eiffjpqe3so6f6qs6jc uid=5jtgo5cftbbc7du17n63nznxac ip=192.168.3.68 Failed to open TLS connection [details: tls: first record does not look like a TLS handshake]
[2015/10/07 11:24:34 UTC] [DEBG] /api/v1/admin/test_email
[2015/10/07 11:24:34 UTC] [EROR] /api/v1/admin/test_email:SendMail code=500 rid=nmohb5fdzfnjuq8njtq1cz7f5h uid=5jtgo5cftbbc7du17n63nznxac ip=192.168.3.68 Failed to open TLS connection [details: tls: first record does not look like a TLS handshake]
STARTTLS Errors
2015/10/08 08:27:06 UTC] [DEBG] /api/v1/admin/test_email
[2015/10/08 08:27:20 UTC] [EROR] /api/v1/admin/test_email:SendMail code=500 rid=f6o6up6ebirbun5s7eh89a991c uid=5jtgo5cftbbc7du17n63nznxac ip=192.168.2.112 Failed to authenticate on SMTP server [details: 504 5.7.4 Unrecognized authentication type]
[2015/10/08 08:27:24 UTC] [DEBG] /api/v1/admin/logs
[2015/10/08 08:27:55 UTC] [DEBG] /api/v1/admin/test_email
[2015/10/08 08:28:05 UTC] [EROR] /api/v1/admin/test_email:SendMail code=500 rid=os9anks597gybgq35e5imudx5y uid=5jtgo5cftbbc7du17n63nznxac ip=192.168.2.112 Failed to authenticate on SMTP server [details: 504 5.7.4 Unrecognized authentication type]
[2015/10/08 08:28:08 UTC] [DEBG] /api/v1/admin/logs
I also followed the guide here https://github.com/mattermost/platform/blob/master/doc/install/SMTP-Email-Setup.md to enable email.
My config is:
"EmailSettings": {
"SendEmailNotifications": true,
"RequireEmailVerification": true,
"FeedbackName": "no-reply",
"FeedbackEmail": "no-reply@<mydomain>",
"SMTPUsername": "<user>@<mydomain>",
"SMTPPassword": "<password>",
"SMTPServer": "smtp.office365.com",
"SMTPPort": "587",
"ConnectionSecurity": "TLS",
"InviteSalt": "bjlSR4QqkXFBr7TP4oDzlfZmcNuH9YoS",
"PasswordResetSalt": "vZ4DcKyVVRlKHHJpexcuXzojkE5PZ5eL",
"ApplePushServer": "",
"ApplePushCertPublic": "",
"ApplePushCertPrivate": ""
I do not have "ByPassEmail" in /config_docker.json. Did something change in V1.0 to enable email?
