[SOLVED] Apache reverse proxy with MM 4.0
Hi
In the changelog for MM 4.0, the following is mentioned for NGINX:
If you are using NGINX as a proxy for the Mattermost Server, replace the location /api/v3/users/websocket { line with location ~ /api/v[0-9]+/(users/)?websocket$ { in the /etc/nginx/sites-available/mattermost NGINX configuration file.
What is the appropriate change for apache (given this config: Redirect)
thanks!
-R
I have not personally tested it but I suppose it would be something like this:
<VirtualHost *:80>
  # If you're not using a subdomain you may need to set a ServerAlias to:
  # ServerAlias www.mydomain.com
  ServerName mysubdomain.mydomain.com
  ServerAdmin hostmaster@mydomain.com
  ProxyPreserveHost On
  # setup the proxy
  <Proxy *>
         Order allow,deny
         Allow from all
  </Proxy>
  # Set web sockets
  RewriteEngine On
  RewriteCond %{REQUEST_URI} ^/api/v[0-9]+/(users/)?websocket [NC,OR]
  RewriteRule .* wss://127.0.0.1:8065%{REQUEST_URI} [P,QSA,L]
  RewriteCond %{DOCUMENT_ROOT}/%{REQUEST_FILENAME} !-f
        # This line simply forces HTTPS
  RewriteRule (.*) https://%{SERVER_NAME}%{REQUEST_URI} [END,QSA,R=permanent]
  <LocationMatch "^/api/v(?<apiversion>[0-9]+)/(?<apiusers>users/)?websocket">
        Require all granted
        ProxyPass ws://127.0.0.1:8065/api/v%{env:MATCH_APIVERSION}/%{env:MATCH_APIUSERS}websocket
        ProxyPassReverse ws://127.0.0.1:8065/api/v%{env:MATCH_APIVERSION}/%{env:MATCH_APIUSERS}websocket
        ProxyPassReverseCookieDomain 127.0.0.1 mysubdomain.mydomain.com
  </LocationMatch>
  <Location />
        Require all granted
        ProxyPass http://127.0.0.1:8065/
  </Location>
</VirtualHost>
Perhaps some one more proficient on the subject can enlighten you.
Sorry for the very delayed response…
Finally got the opportunity to try this out - it works perfectly, thanks!
Created a pull request to update the docs page: https://github.com/mattermost/docs/pull/1470
Thanks for trying it and confirming it works + the PR which is very welcome!
