We have an GitLab Server running with Mattermost integrated. In Mattermost there are two Custom Slash commands.
One is a custom for giphy bot, the other is a Custom Slash Command in our GitLab instance.
The custom GitLab one works. The command for giphy bot not.
We have a running GitLab Instance with version 10.0.3 and Mattermost with version 4.2.0.
We have also running docker container that listens for Requests triggered by the /giphy command.
So we created a custom slash command with command trigger word “giphy” so we can show a random gif in channels or direct messaging. But it does not work.
When in channel or direct message, then /giphy xyz should trigger the custom slash command and present a random gif.
The error message is “Command with a trigger of ‘giphy’ failed”
Before version 4.2.0 of mattermost the slash command worked. It seems like it could be a problem with the Request URL. I have also found https://mattermost.atlassian.net/browse/PLT-7193 but I think that has nothing to do with the failure.
Somebody having the same issue? Maybe someone can help?
