[solved] Docker Compose Mattermost with nginx Proxy dont work
Mattermost docker image with nginx proxy dont work
i install mattermost with docker-compose with this config =
version: “2”
services:
db:
build: db
restart: unless-stopped
volumes:
- ./volumes/db/var/lib/postgresql/data:/var/lib/postgresql/data
environment:
- POSTGRES_USER=user
- POSTGRES_PASSWORD=pw
- POSTGRES_DB=mattermost
# uncomment the following to enable backup
# - AWS_ACCESS_KEY_ID=XXXX
# - AWS_SECRET_ACCESS_KEY=XXXX
# - WALE_S3_PREFIX=s3://BUCKET_NAME/PATH
# - AWS_REGION=us-east-1
app:
build:
context: app
# comment out 2 following lines for team edition
# args:
# - edition=team
volumes:
- ./volumes/app/mattermost/logs:/mattermost/logs:rw
environment:
# set same as db credentials and dbname
- MM_USERNAME=user
- MM_PASSWORD=pw
- MM_DBNAME=mattermost
# in case your config is not in default location
#- MM_CONFIG=/mattermost/config/config.json
ports:
- “8000:443”
links:
- db:db
i bring it up wit docker-compuse up -d
my nginx proxy config file =
upstream mattermost {
server 127.0.0.1:8000;
server {
server_name mydomain;
proxy_set_header Connection “upgrade”;
client_max_body_size 50M;
proxy_buffers 256 16k;
proxy_buffer_size 16k;
proxy_read_timeout 600s;
proxy_pass http://mattermost;
location / {
proxy_set_header Connection “”;
proxy_cache mattermost_cache;
proxy_cache_revalidate on;
proxy_cache_min_uses 2;
proxy_cache_lock on;
when i go to the site its come nginx bad gateway. i read many instruction but i dont know where is my failure.
in the nginx log file =
connect() failed (111: Connection refused) while connecting to upstream, client:
Thanks Felix
Hi @Felix,
Were you following the “How do I setup an NGINX proxy with the Mattermost Docker installation?” section of this doc https://docs.mattermost.com/install/config-proxy-nginx.html?
first thanks for you reply.
i see the link and i read the link, but is the doc real or outdatet.
i read thats mattermost 5… the port is now 8000 and not 8065. The docker app container say also 8000. So now i ám confused.
Also when i expose ports in the config file, always is come thats blocked not ended.
To my understand.
Port is 8065?
I bind my nginx proxy to 127.0.0.1:8065?
sry too much frustration and i think it is my fault :slight_smile:
@pichouk Do you know more about this issue?
Hi @Felix,
Why did you bind your app container port 8000 to 443 ?
ports:
- “8000:443”
I think you should use port 8000 instead. Mattermost service is not listening on port 443 if you use the Docker image.
Hi pichouk,
that expose was from one test. I set it now again from scratch but also , ist has always error 500.
i post you my settings:
ubuntu , nginx, docker
docker-compose.xml
version: “2”
services:
db:
build: db
read_only: true
volumes:
environment:
- POSTGRES_USER=mmuser
- POSTGRES_PASSWORD=mmuser_password
app:
build:
context: app
# uncomment following lines for team edition or change UID/GID
# args:
# - edition=team
# - PUID=1000
# - PGID=1000
volumes:
- ./volumes/app/mattermost/plugins:/mattermost/plugins:rw
- ./volumes/app/mattermost/client-plugins:/mattermost/client/plugins:rw
environment:
- MM_USERNAME=mmuser
- MM_PASSWORD=mmuser_password
nginx site config
server {
server_name xxx;
location / {
docker ps:
mattermost-docker_db 5432/tcp
mattermost-docker_app 8000/tcp
i have delete the web config in docker-compose, because nginx proxy.
in my nginx log file:
What did I miss? Thank you very much for your time and help. Felix
My debt and excuse me for taking up your time. I set in the nginx the docker ip from mattermost_app and the the upstream is correct.
Thanks again for trying to help me! Felix
You should keep this part I think :
ports:
  - “8000:8000”
I guess you can have something working with this docker-compose.yml
version: “2”
services:
  db:
    build: db
    read_only: true
    volumes:
    environment:
  app:
    build:
      context: app
    volumes:
    environment:
    ports:
      - “8000:8000”
Thanks, it works now when i bind the nginx proxy to the docker ip from the mattermost app with port 8000.
But i have one question, when i uncomment the arg line with the edition or i wrote the port line, docker-compose write a failure:
ERROR: yaml.parser.ParserError: while parsing a block mapping
in “./docker-compose.yml”, line 24, column 7
expected , but found ‘’
in “./docker-compose.yml”, line 26, column 8
args:
- edition=team
or when i set the ports as in your example.
I think it’s just because I made a bad copy paste. I wrote ” instead of ".
If you write
ports:
  - "80:80"
I think it will works better :slight_smile:
I’ve still got the wrong one.
my docker.yml
version: “2”
services:
db:
build: db
read_only: true
volumes:
environment:
- POSTGRES_USER=xxx
- POSTGRES_PASSWORD=xxx
- POSTGRES_DB=xxx
app:
build:
context: app
args:
- edition=team
# - PUID=1000
# - PGID=1000
volumes:
environment:
- MM_USERNAME=xxx
- MM_PASSWORD=xxx
- MM_DBNAME=xxx
ports:
- “8000:8000”
I become the same issues by the edition and the port parameter:
expected , but found ‘?’
its run now :). thanks for all your support.
