I’m following the instructions here. I’m on ubuntu 14.04 server, and it was a fresh install with nothing on it.
When I got to step 8 under “Setup Mattermost Server” and run ./platform I get an error:
[CRIT] Failed to ping db err:dial tcp 192.168.1.2:5432: connection refused
panic: Failed to open sql connection dial tcp 192.168.1.2:5432: connection refused
goroutine 1 [running]:
github.com/mattermost/platform/store.setupConnection(0xb4ddf0, 0x6, 0xc20800bc88, 0x8, 0xc208054120, 0x5d, 0xa, 0xa, 0x4e0500, 0x95d960)
/home/travis/gopath/src/github.com/mattermost/platform/store/sql_store.go:146 +0x581
github.com/mattermost/platform/store.NewSqlStore(0x0, 0x0)
/home/travis/gopath/src/github.com/mattermost/platform/store/sql_store.go:52 +0x106
github.com/mattermost/platform/api.NewServer()
/home/travis/gopath/src/github.com/mattermost/platform/api/server.go:33 +0x15a
main.main()
/home/travis/gopath/src/github.com/mattermost/platform/mattermost.go:55 +0x4d8
goroutine 6 [syscall]:
os/signal.loop()
/usr/local/go/src/os/signal/signal_unix.go:21 +0x1f
created by os/signal.init·1
/usr/local/go/src/os/signal/signal_unix.go:27 +0x35
goroutine 7 [chan receive]:
code.google.com/p/log4go.ConsoleLogWriter.run(0xc208054240, 0x7f4746a23ff0, 0xc20802c008)
/home/travis/gopath/src/github.com/mattermost/platform/Godeps/_workspace/src/code.google.com/p/log4go/termlog.go:27 +0x7a
created by code.google.com/p/log4go.NewConsoleLogWriter
/home/travis/gopath/src/github.com/mattermost/platform/Godeps/_workspace/src/code.google.com/p/log4go/termlog.go:19 +0x6b
goroutine 8 [select]:
code.google.com/p/log4go.func·002()
/home/travis/gopath/src/github.com/mattermost/platform/Godeps/_workspace/src/code.google.com/p/log4go/filelog.go:84 +0xa53
created by code.google.com/p/log4go.NewFileLogWriter
/home/travis/gopath/src/github.com/mattermost/platform/Godeps/_workspace/src/code.google.com/p/log4go/filelog.go:116 +0x3da
goroutine 9 [chan receive]:
database/sql.(*DB).connectionOpener(0xc20803d540)
/usr/local/go/src/database/sql/sql.go:589 +0x4c
created by database/sql.Open
/usr/local/go/src/database/sql/sql.go:452 +0x31c
This problem is almost identical to this one, but they just say they were able to fix that first problem, and never said how.
my 5432 port is open;
sudo netstat -tulpn
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 922/sshd
tcp 0 0 127.0.0.1:5432 0.0.0.0:* LISTEN 1028/postgres
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 1121/nginx
tcp6 0 0 :::22 :::* LISTEN 922/sshd
tcp6 0 0 ::1:5432 :::* LISTEN 1028/postgres
Any ideas?
