[Solved] Problem with migration-assist pgloader when migrating from MySQL to Posgres
migration-assist pgloader fails when migrating from MySQL to Postgres
migration-assist pgloader --mysql=“<MYSQL_DSN>” --postgres=“<POSTGRES_DSN>” > migration.load
  1. migration-assist mysql "<MYSQL_DSN>" succeeded
  2. migration-assist postgres "<POSTGRES_DSN>" --run-migrations --mattermost-version="v10.1.1" succeeded
  3. migration-assist pgloader --mysql="<MYSQL_DSN>" --postgres="<POSTGRES_DSN>" > migration.load failed with error
For 3) my command looks in detail like this:
./migration-assist pgloader --postgres="postgres://mattermost_db1:PASSWORD@127.0.0.1:5432/mattermost_db1" --mysql="mattermost_db1:PASSWORD@tcp(127.0.0.1:3306)/mattermost_db1" > migration.load
For 3) the error message is like this:
An Error Occurred: could not generate config: could not parse mysql DSN: no match found
Can someone help and tell me if my DSNs are somewhere wrong?
Solved, there had been a special char (@) in the password
Thank you autoflow for following up with the solution! Glad to hear all is working now.
could you give an example of your mysql dsn that actually worked? I’m experiencing the same issue & can’t figure out why.
