SQL error when upgrading from 6.0.4 to 6.7.2
For feature requests, please see: https://portal.productboard.com/mattermost/33-what-matters-to-you.
Mattermost service fails to start after upgrade with a sql error
upgrading from 6.0.4 to 6.7.2 in order to keep upgrading to meet compliance
ran the upgrade steps and mattermost service won’t start
– Unit mattermost.service has begun starting up.
Jan 26 04:29:26 ip-172-31-39-85 mattermost[24349]: {“timestamp”:“2023-01-26 04:29:26.122 Z”,“level”:“info”,“msg”:“Server is initializing…”,“caller”:“app/server.go:262”,“go_version”:“go1.18.1”}
Jan 26 04:29:26 ip-172-31-39-85 mattermost[24349]: {“timestamp”:“2023-01-26 04:29:26.125 Z”,“level”:“info”,“msg”:“Pinging SQL”,“caller”:“sqlstore/store.go:226”,“database”:“master”}
Jan 26 04:29:26 ip-172-31-39-85 mattermost[24349]: {“timestamp”:“2023-01-26 04:29:26.150 Z”,“level”:“info”,“msg”:“Pinging SQL”,“caller”:“sqlstore/store.go:226”,“database”:“master”}
Jan 26 04:29:26 ip-172-31-39-85 mattermost[24349]: {“timestamp”:“2023-01-26 04:29:26.175 Z”,“level”:“fatal”,“msg”:“Failed to apply database migrations.”,“caller”:“sqlstore/store.go:163”,“error”:"driver: mysql, mess
Jan 26 04:29:26 ip-172-31-39-85 systemd[1]: mattermost.service: Main process exited, code=exited, status=1/FAILURE
Jan 26 04:29:26 ip-172-31-39-85 systemd[1]: mattermost.service: Failed with result ‘exit-code’.
Jan 26 04:29:26 ip-172-31-39-85 systemd[1]: Failed to start Mattermost.
– Subject: Unit mattermost.service has failed
– Defined-By: systemd
– Support: http://www.ubuntu.com/support
– Unit mattermost.service has failed.
– The result is RESULT.
Trying not to restore as it’s on AWS
Hi @will.graham and welcome to the Mattermost forums!
Can you please have a look at your Mattermost logfile? The default location is /opt/mattermost/logs/mattermost.log. It might contain some additional hints that would help us to idenfity the reason for the issue you’re seeing here.
{“timestamp”:“2023-01-26 04:41:34.802 Z”,“level”:“info”,“msg”:“Server is initializing…”,“caller”:“app/server.go:262”,“go_version”:“go1.18.1”}
{“timestamp”:“2023-01-26 04:41:34.803 Z”,“level”:“info”,“msg”:“Pinging SQL”,“caller”:“sqlstore/store.go:226”,“database”:“master”}
{“timestamp”:“2023-01-26 04:41:34.829 Z”,“level”:“info”,“msg”:“Pinging SQL”,“caller”:“sqlstore/store.go:226”,“database”:“master”}
{“timestamp”:“2023-01-26 04:41:34.866 Z”,“level”:“fatal”,“msg”:“Failed to apply database migrations.”,“caller”:“sqlstore/store.go:163”,“error”:“driver: mysql, message: failed when applying migration, command: apply_migration, originalError: Error 1304: PROCEDURE Migrate_LastRootPostAt already exists, query: \n\nCREATE PROCEDURE Migrate_LastRootPostAt ()\nBEGIN\nDECLARE\n\tLastRootPostAt_EXIST INT;\n\tSELECT\n\t\tCOUNT(*)\n\tFROM\n\t\tINFORMATION_SCHEMA.COLUMNS\n\tWHERE\n\t\tTABLE_NAME = ‘Channels’\n\t\tAND table_schema = DATABASE()\n\t\tAND COLUMN_NAME = ‘LastRootPostAt’ INTO LastRootPostAt_EXIST;\n\tIF(LastRootPostAt_EXIST = 0) THEN\n ALTER TABLE Channels ADD COLUMN LastRootPostAt bigint DEFAULT 0;\n\t\tUPDATE\n\t\t\tChannels\n\t\t\tINNER JOIN (\n\t\t\t\tSELECT\n\t\t\t\t\tChannels.Id channelid,\n\t\t\t\t\tCOALESCE(MAX(Posts.CreateAt), 0) AS lastrootpost\n\t\t\t\tFROM\n\t\t\t\t\tChannels\n\t\t\t\t\tLEFT JOIN Posts FORCE INDEX (idx_posts_channel_id_update_at) ON Channels.Id = Posts.ChannelId\n\t\t\t\tWHERE\n\t\t\t\t\tPosts.RootId = ‘’\n\t\t\t\tGROUP BY\n\t\t\t\t\tChannels.Id) AS q ON q.channelid = Channels.Id SET LastRootPostAt = lastrootpost;\n\tEND IF;\nEND;\n\tCALL Migrate_LastRootPostAt ();\n\tDROP PROCEDURE IF EXISTS Migrate_LastRootPostAt;\n\n”}
thanks for replying so quickly btw Alexander
Alright, thanks - I’m not 100% sure I can read that out of the logs, but is that a MySQL or PostgreSQL deployment you’re having here?
Can you please connect to your Mattermost database and run the following command:
Then try to start the server again and see if it works now. If not, please look at your mattermost.log file again and share the last few lines again.
it’s mysql. FYI this command worked and you saved my sanity, if not my job. So thank you very much for your help!
You’re welcome - glad to hear it’s up and running again :slight_smile:
