When setting up GitLab + Mattermost, http works, however, when https is enabled, it just redirects to gitlab, and doesn’t go to Mattermost.
Set up the following lines in gitlab.rb:
mattermost['service_use_ssl'] = true
mattermost_nginx['redirect_http_to_https'] = true
mattermost_nginx['ssl_certificate'] = "/etc/letsencrypt/live/[domain]/fullchain.pem"
mattermost_nginx['ssl_certificate_key'] = "/etc/letsencrypt/live/[domain]/privkey.pem"
mattermost_nginx['custom_gitlab_mattermost_server_config'] = "location ^~ /.well-known {\n alias /var/www/letsencrypt/.well-known;\n}\n"
SSL should be working on both Gitlab and Mattermost.
See the summary. Don’t know where to even get an error log for this type of issue. It reconfigured successfully, so I have no idea.
Edit 1/5/2018: Moved to relevant topic section.
