"pq: SSL is not enabled on the server"
Follow this guide to set up the Postgres server: Prepare your Mattermost database - Mattermost documentation
Then followed the advice from support for adding the ?sslmode=disable to the DataSource in the Mattermost config.json file.
Expect it to bypass trying to use SSL for the connection.
$ bin/mattermost
{"timestamp":"2024-12-17 21:11:49.993 Z","level":"debug","msg":"Advanced logging config not provided for logging","caller":"platform/config.go:165"}
{"timestamp":"2024-12-17 21:11:49.993 Z","level":"debug","msg":"Advanced logging config not provided for notification logging","caller":"platform/config.go:165"}
{"timestamp":"2024-12-17 21:11:49.994 Z","level":"info","msg":"Successfully connected to cache backend","caller":"platform/service.go:185","backend":"lru","result":"OK"}
{"timestamp":"2024-12-17 21:11:49.994 Z","level":"info","msg":"Server is initializing...","caller":"platform/service.go:188","go_version":"go1.22.6"}
{"timestamp":"2024-12-17 21:11:49.995 Z","level":"info","msg":"Pinging SQL","caller":"sql/sql_utils.go:67","database":"master","dataSource":"matteradmin:password@mydomain.com:5432/mattermost?sslmode=disable"}
{"timestamp":"2024-12-17 21:11:50.000 Z","level":"error","msg":"Failed to ping DB","caller":"sql/sql_utils.go:75","database":"master","dataSource":"matteradmin:password@mydomain.com:5432/mattermost?sslmode=disable","retrying in seconds":10,"error":"pq: SSL is not enabled on the server"}
Shouldn’t adding the sslmode=disable correct this?
Fedora Server 41
Postgresql 16.3
Mattermost 10.3.1
