Update My SQL a Postgre
Good afternoon, I’ve tried migrating from MySQL to PostgreSQL in every way possible and have only encountered one problem after another.
  • I made a backup
  • I downloaded the migration tool
  • I tried using pgloader. However, the backup isn’t in the correct format, and the version of pgloader that installs isn’t the correct version because it has a bug. The steps I followed were:
sudo apt update
sudo apt install postgresql-16 postgresql-client-16
sudo -u postgres createuser -P mattermost
sudo -u postgres createdb -O mattermost mattermostdb
sudo apt install pgloader
sudo mysqldump --databases mattermostdb > mattermost.sql
nano migrate.load
LOAD DATABASE
FROM mysql://root:your_password@localhost/mattermostdb
INTO postgresql://mattermost:your_password@localhost/mattermostdb
WITH include drop, create tables, create indexes, reset sequences
SET work_mem to ‘16MB’,
maintenance_work_mem to ‘512 MB’,
search_path to 'publi
CAST type datetime to timestamptz drop default drop not null,
type timestamp to timestamptz drop default drop not null;
pgloader migrate.load
However, the database won’t connect due to password incompleteness. It’s always one error after another. And since I have no experience, I’m completely lost. I’ve also tried installing DBeaver to migrate, but it gives me an error. Can you help me?
hello rrmfar, I just completed a migration and update of mattermost successfully (from mariadb via mysql to postgres-14) . The one thing that sticks out and that I don’t remember seeing in guides is importing the mysqldump into directly, .. you are installing pgloader, but not using it?
you want my step by step to test?
by ‘not using pgloader’ I mean the migration-assist part (I can see you use pgloader itself..)
./migration-assist postgres “postgres://mmuser:XXXXX@localhost:5432/mattermost?sslmode=disable” --run-migrations --mattermost-version=“10.8.0”
dnf install pgloader
./migration-assist pgloader --mysql=“mmuser:XXXXX@tcp(localhost:3306)/mattermost” --postgres=“postgres://mmuser:XXXXX@localhost:5432/mattermost?sslmode=disable” --remove-null-chars > migration.load
It was my understanding that this migration.load contains what migrates from mysql to postgres, and it’s much more than just importing the database
@Horned1
PostgreSQL 14 using port: 5433 for default. (not be as port: 5432 before)
Pls, check mattermost/config/config.json or /etc/postgresql/14/main/pg_hba.conf to matching listen port.
Si no te genero inconvenientes me gustaria tu ayuda para poder realizar el proceso. Gracias
The step by step I successfully used (most of this is in the docs: Automated PostgreSQL migration - Mattermost documentation )
Preparations
cd /tmp/
wget https://github.com/mattermost/migration-assist/releases/download/v0.5/migration-assist-Linux-x86_64.tar.gz
tar -xvf migration-assist-Linux-x86_64.tar.gz
dnf install -y https://download.postgresql.org/pub/repos/yum/reporpms/EL-9-x86_64/pgdg-redhat-repo-latest.noarch.rpm
dnf install postgresql14-server.x86_64 postgresql14.x86_64 postgresql14-contrib.x86_64 --nobest
/usr/pgsql-14/bin/postgresql-14-setup initdb
systemctl start postgresql-14
systemctl enable postgresql-14
systemctl stop mattermost
Start the migration
./migration-assist mysql “mmuser:XXX@tcp(localhost:3306)/mattermost” --fix-artifacts --fix-unicode --fix-varchar
in the guide there is a single command you are supposed to run, but after finfing this info on some forums I did all these commands separately and it solved my issues
[root@mattermost:/tmp]# sudo -u postgres psql
psql (14.19)
Type “help” for help.
postgres=# create database mattermost;
CREATE DATABASE
postgres=# CREATE USER mmuser WITH PASSWORD ‘XXX’;
CREATE ROLE
postgres=# GRANT ALL PRIVILEGES ON DATABASE mattermost to mmuser;
GRANT
postgres=# ALTER DATABASE mattermost OWNER TO mmuser;
ALTER DATABASE
postgres=# GRANT USAGE, CREATE ON SCHEMA PUBLIC TO mmuser;
GRANT
postgres=# \c mattermost;
You are now connected to database “mattermost” as user “postgres”.
mattermost=# SELECT current_database();
current_database
mattermost
(1 row)
mattermost=# ALTER SCHEMA public OWNER to mmuser;
ALTER SCHEMA
mattermost=# GRANT ALL ON SCHEMA public to mmuser;
GRANT
mattermost=# \q
the command below should have your own mattermost version of course
./migration-assist postgres “postgres://mmuser:XXX@localhost:5432/mattermost?sslmode=disable” --run-migrations --mattermost-version=“10.8.0”
./migration-assist pgloader --mysql=“mmuser:XXX@tcp(localhost:3306)/mattermost” --postgres=“postgres://mmuser:XXX@localhost:5432/mattermost?sslmode=disable” --remove-null-chars > migration.load
pgloader migration.load > migration.log
./migration-assist postgres post-migrate --create-indexes “postgres://mmuser:XXX@localhost:5432/mattermost?sslmode=disable”
./migration-assist pgloader boards --mysql=“mmuser:XXX@tcp(localhost:3306)/mattermost” --postgres=“postgres://mmuser:XXX@localhost:5432/mattermost?sslmode=disable” > boards.load
./migration-assist pgloader playbooks --mysql=“mmuser:XXX@tcp(localhost:3306)/mattermost” --postgres=“postgres://mmuser:XXX@localhost:5432/mattermost?sslmode=disable” > playbooks.load
./migration-assist pgloader calls --mysql=“mmuser:XXX@tcp(localhost:3306)/mattermost” --postgres=“postgres://mmuser:XXX@localhost:5432/mattermost?sslmode=disable” > calls.load
pgloader boards.load > boards_migration.log
pgloader playbooks.load > playbooks_migration.log
pgloader calls.load > calls_migration.log
set the sql connector to PSQL and change the unit-file to point to PostgreSQL as in the guide
vi /opt/mattermost/config/config.json
vi /etc/systemd/system/mattermost.service
Start and check for errors
systemctl start mattermost
journalctl -xeu mattermost.service
Then update as in docs ( Upgrade Mattermost Server - Mattermost documentation )
wget https://releases.mattermost.com/11.1.0/mattermost-11.1.0-linux-amd64.tar.gz
tar -xvf mattermost-11.1.0-linux-amd64.tar.gz mattermost/
cd /opt/
cp -ra mattermost/ mattermost-back-$(date +‘%F-%H-%M’)/
sudo find mattermost/ mattermost/client/ -mindepth 1 -maxdepth 1 ! ( -type d ( -path mattermost/client -o -path mattermost/client/plugins -o -path mattermost/config -o -path mattermost/logs -o -path mattermost/plugins -o -path mattermost/data ) -prune ) | sort | sudo xargs rm -r
cp -an /tmp/mattermost/. mattermost/
chown -R mattermost:mattermost mattermost
setcap cap_net_bind_service=+ep ./mattermost/bin/mattermost
Finally the forumposts I used at some point soving this issue for me
search path error
config that was depricated
https://support.mattermost.com/hc/en-us/articles/42915463550996-Mattermost-11-x-Upgrade-Error-Hidden-Archived-Channels
I sincerely appreciate the steps you provided; however, I am running everything on Ubuntu 24. I installed the tool via sudo apt install pgloader, but it installed a version that reports compatibility issues with MySQL. From that point onward, the repositories are misconfigured, and I inevitably encounter the same problems again.
cd /tmp/
sudo sh -c 'wget -O /etc/apt/trusted.gpg.d/pgdg.asc https://www.postgresql.org/media/keys/ACCC4CF8.asc'
sudo sh -c 'echo "deb http://apt.postgresql.org/pub/repos/apt/ $(lsb_release -cs)-pgdg main" > /etc/apt/sources.list.d/pgdg.list'
sudo apt update
sudo apt install postgresql-14
sudo systemctl status postgresql  # Confirmed operational
./migration-assist mysql "mmuser:rg22090801@tcp(localhost:3306)/mattermost" --fix-artifacts --fix-unicode --fix-varchar
The database creation and permission assignments executed flawlessly.
./migration-assist postgres post-migrate --create-indexes "postgres://mmuser:XXX@localhost:5432/mattermost?sslmode=disable"
./migration-assist pgloader boards --mysql="mmuser:XXX@tcp(localhost:3306)/mattermost" --postgres="postgres://mmuser:XXX@localhost:5432/mattermost?sslmode=disable" > boards.load
./migration-assist pgloader playbooks --mysql="mmuser:XXX@tcp(localhost:3306)/mattermost" --postgres="postgres://mmuser:XXX@localhost:5432/mattermost?sslmode=disable" > playbooks.load
./migration-assist pgloader calls --mysql="mmuser:XXX@tcp(localhost:3306)/mattermost" --postgres="postgres://mmuser:XXX@localhost:5432/mattermost?sslmode=disable" > calls.load
However, the following errors occurred during execution:
2025-11-25T18:21:31.032000Z LOG pgloader version "3.6.7~devel"
2025-11-25T18:21:31.317003Z LOG Migrating from #<MYSQL-CONNECTION mysql://mmuser@localhost:3306/mattermost {1006EA2D33}>
2025-11-25T18:21:31.317003Z LOG Migrating into #<PGSQL-CONNECTION pgsql://mmuser@localhost:5432/mattermost {1006EA2F23}>
2025-11-25T18:21:31.384004Z ERROR mysql: Failed to connect to mysql at "localhost" (port 3306) as user "mmuser": Condition QMYND:MYSQL-UNSUPPORTED-AUTHENTICATION >
2025-11-25T18:21:31.412004Z ERROR Database error 42P01: relation "mattermost.focalboard_blocks" does not exist
QUERY: UPDATE mattermost.focalboard_blocks SET "fields" = '{}'::json WHERE "fields"::text = '';
Thereafter, I was unable to proceed further—encountering persistent errors while attempting to restart the service. I even performed system updates and switched the database connection to PostgreSQL, yet the issues persisted.
That authentication error.. The problem is that currently pgloader doesn’t support caching_sha2_password authentication plugin, which is default for MySQL 8, whereas older MySQL versions use mysql_native_password plugin.
Also the error that the focalboards is missing is likely because of an error in migrating the ‘boards’ part, check the boards_migration.log for errors
If you are using MariaDB instead of Mysql (as I did) this is where my migration failed, some timestamps in focalboards has the wrong syntax on mariadb
